Ana içeriğe geç
Compaq Evo N1000v Floppy Drive Replacement
Neye ihtiyacın var
    1. Compaq Evo N1000v Floppy Drive Replacement, LED Cover: adım 1, 1 resimden 1.
      • Flip the laptop over with the rear panel facing forward.
      FixBot'a Sor
      Yorum Ekle
    2. Compaq Evo N1000v Floppy Drive Replacement: adım 2, 1 resimden 1.
      • Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
      FixBot'a Sor
      Yorum Ekle
    3. Compaq Evo N1000v Floppy Drive Replacement: adım 3, 1 resimden 1.
      • Flip the laptop back over with the front facing forward. Open the screen.
      FixBot'a Sor
      Yorum Ekle
    4. Compaq Evo N1000v Floppy Drive Replacement: adım 4, 1 resimden 1.
      • Locate the F1 and F2 keys near the top left corner of the keyboard.
      FixBot'a Sor
      Yorum Ekle
    5. Compaq Evo N1000v Floppy Drive Replacement: adım 5, 1 resimden 1.
      • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
      FixBot'a Sor
      Yorum Ekle
    6. Compaq Evo N1000v Floppy Drive Replacement: adım 6, 1 resimden 1.
      • Locate the Scroll and Pause keys near the top right corner of the keyboard.
      FixBot'a Sor
      Yorum Ekle
    7. Compaq Evo N1000v Floppy Drive Replacement: adım 7, 1 resimden 1.
      • While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
      FixBot'a Sor
      Yorum Ekle
    8. Compaq Evo N1000v Floppy Drive Replacement: adım 8, 2 resimden 1. Compaq Evo N1000v Floppy Drive Replacement: adım 8, 2 resimden 2.
      • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
      FixBot'a Sor
      Yorum Ekle
    1. Compaq Evo N1000v Floppy Drive Replacement, Keyboard: adım 9, 1 resimden 1.
      • Lift the back edge of the keyboard and pull towards the screen.
      FixBot'a Sor
      Yorum Ekle
    2. Compaq Evo N1000v Floppy Drive Replacement: adım 10, 1 resimden 1.
      • Pull the cable and lift up to release.
      FixBot'a Sor
      Yorum Ekle
    3. Compaq Evo N1000v Floppy Drive Replacement: adım 11, 1 resimden 1.
      • Remove the keyboard.
      FixBot'a Sor
      Yorum Ekle
    1. Compaq Evo N1000v Floppy Drive Replacement, Palm Rest: adım 12, 1 resimden 1.
      • Close the laptop and flip it so the rear panel is facing up.
      FixBot'a Sor
      Yorum Ekle
    2. Compaq Evo N1000v Floppy Drive Replacement: adım 13, 1 resimden 1.
      • Using the TR8 Torx screwdriver, remove the six screws from the back case.
      FixBot'a Sor
      Yorum Ekle
    3. Compaq Evo N1000v Floppy Drive Replacement: adım 14, 1 resimden 1.
      • Remove the battery.
      • Remove the screw from the metal support on the case edge with a Torx T8 screwdriver.
      • Flip the laptop over again so the top is facing up.
      • Open the laptop screen and face it towards you.
      FixBot'a Sor
      Yorum Ekle
    4. Compaq Evo N1000v Floppy Drive Replacement: adım 15, 1 resimden 1.
      • Lift the the palm rest up from the front edge of the laptop and swing it towards the screen.
      • Be gentle as it is connected by some cables.
      FixBot'a Sor
      Yorum Ekle
    5. FixBot'a Sor
      Yorum Ekle
    6. Compaq Evo N1000v Floppy Drive Replacement: adım 17, 1 resimden 1.
      • Disconnect the second ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    7. Compaq Evo N1000v Floppy Drive Replacement: adım 18, 1 resimden 1.
      • Remove the palm rest.
      FixBot'a Sor
      Yorum Ekle
      • Locate and remove the three screws shown in picture.
      FixBot'a Sor
      Yorum Ekle
    1. Compaq Evo N1000v Floppy Drive Replacement: adım 20, 1 resimden 1.
      • Lift up and remove floppy drive from the palm rest.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Alex Hernandez
49 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 29-74, Johann Spring 2010 Cal Poly, Team 29-74, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S29G74
3 Üyeler
28 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 3,834
