Ana içeriğe geç
Compaq Evo N1000v Keyboard Replacement
Neye ihtiyacın var
  1. Compaq Evo N1000v Keyboard Replacement, LED Cover: adım 1, 1 resimden 1.
    • Flip the laptop over with the rear panel facing forward.
    FixBot'a Sor
    Yorum Ekle
  2. Compaq Evo N1000v Keyboard Replacement: adım 2, 1 resimden 1.
    • Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
    FixBot'a Sor
    Yorum Ekle
  3. Compaq Evo N1000v Keyboard Replacement: adım 3, 1 resimden 1.
    • Flip the laptop back over with the front facing forward. Open the screen.
    FixBot'a Sor
    Yorum Ekle
  4. Compaq Evo N1000v Keyboard Replacement: adım 4, 1 resimden 1.
    • Locate the F1 and F2 keys near the top left corner of the keyboard.
    FixBot'a Sor
    Yorum Ekle
  5. Compaq Evo N1000v Keyboard Replacement: adım 5, 1 resimden 1.
    • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
    FixBot'a Sor
    Yorum Ekle
  6. Compaq Evo N1000v Keyboard Replacement: adım 6, 1 resimden 1.
    • Locate the Scroll and Pause keys near the top right corner of the keyboard.
    FixBot'a Sor
    Yorum Ekle
  7. Compaq Evo N1000v Keyboard Replacement: adım 7, 1 resimden 1.
    • While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
    FixBot'a Sor
    Yorum Ekle
  8. Compaq Evo N1000v Keyboard Replacement: adım 8, 2 resimden 1. Compaq Evo N1000v Keyboard Replacement: adım 8, 2 resimden 2.
    • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
    FixBot'a Sor
    Yorum Ekle
  9. Compaq Evo N1000v Keyboard Replacement, Keyboard: adım 9, 1 resimden 1.
    • Lift the back edge of the keyboard and pull towards the screen.
    FixBot'a Sor
    Yorum Ekle
  10. Compaq Evo N1000v Keyboard Replacement: adım 10, 1 resimden 1.
    • Pull the cable and lift up to release.
    FixBot'a Sor
    Yorum Ekle
  11. Compaq Evo N1000v Keyboard Replacement: adım 11, 1 resimden 1.
    • Remove the keyboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Bir başkası bu kılavuzu tamamladı.
kim
77 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 29-74, Johann Spring 2010 Cal Poly, Team 29-74, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S29G74
3 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 32
Her zaman: 4,145
