Ana içeriğe geç
Conair Infiniti Pro Model 259NP Cold Shot Button Replacement
Neye ihtiyacın var
  1. Conair Infiniti Pro Model 259NP Cold Shot Button Replacement, Back Panel: adım 1, 1 resimden 1.
    • Caution: Unplug the hair dryer before attempting this guide. Leaving the device plugged in may result in electrocution and damage to the device.
    • Hold the hair dryer by the handle so that the back panel faces up.
    FixBot'a Sor
    Yorum Ekle
  2. Conair Infiniti Pro Model 259NP Cold Shot Button Replacement: adım 2, 2 resimden 1. Conair Infiniti Pro Model 259NP Cold Shot Button Replacement: adım 2, 2 resimden 2.
    • Remove the two 15.875 mm Phillips #2 screws from the back panel.
    FixBot'a Sor
    Yorum Ekle
  3. Conair Infiniti Pro Model 259NP Cold Shot Button Replacement: adım 3, 3 resimden 1. Conair Infiniti Pro Model 259NP Cold Shot Button Replacement: adım 3, 3 resimden 2. Conair Infiniti Pro Model 259NP Cold Shot Button Replacement: adım 3, 3 resimden 3.
    • Starting from where the cord attaches to the handle, pull apart the two plastic panels.
    • Continue separating the back panel, working along the seam.
    • With moderate force, completely remove the back panel from the hair dryer.
    FixBot'a Sor
    Yorum Ekle
  4. Conair Infiniti Pro Model 259NP Cold Shot Button Replacement, Fan Motor Assembly: adım 4, 2 resimden 1. Conair Infiniti Pro Model 259NP Cold Shot Button Replacement, Fan Motor Assembly: adım 4, 2 resimden 2.
    • Hold the hair dryer by the nozzle so that the handle points to the left.
    • Remove the two 1-inch Phillips #2 screws from the back of the fan motor.
    FixBot'a Sor
    Yorum Ekle
  5. Conair Infiniti Pro Model 259NP Cold Shot Button Replacement: adım 5, 3 resimden 1. Conair Infiniti Pro Model 259NP Cold Shot Button Replacement: adım 5, 3 resimden 2. Conair Infiniti Pro Model 259NP Cold Shot Button Replacement: adım 5, 3 resimden 3.
    • Caution: If you recently used the hair dryer, wait at least 10 minutes before attempting this step. The heating element may still be very hot and can cause serious burns.
    • Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
    • Lift the attached electrical wiring and heat shield completely out of the hair dryer.
    FixBot'a Sor
    Yorum Ekle
  6. Conair Infiniti Pro Model 259NP Cold Shot Button Replacement, Cold Shot Button: adım 6, 1 resimden 1.
    • Caution: Do not attempt to open or tamper with the capacitor. You may suffer severe electrical shocks.
    • Hold the electrical switches so that the wires are facing upwards.
    FixBot'a Sor
    Yorum Ekle
  7. Conair Infiniti Pro Model 259NP Cold Shot Button Replacement: adım 7, 1 resimden 1.
    • Focus on the button closest along the wires to the fan motor.
    • Desolder the button at the circled locations.
    • To reattach the new button, resolder at the same points. Be sure the wires connect to the correct locations.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Timothy Lo
1.214 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-58, Amido Spring 2014 Cal Poly, Team 10-58, Amido Spring 2014 üyesi
CPSU-AMIDO-S14S10G58
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 37
Her zaman: 2,362
