Ana içeriğe geç
Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement
Neye ihtiyacın var
  1. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement, Back Panel: adım 1, 1 resimden 1.
    • Caution: Unplug the hair dryer before attempting this guide. Leaving the device plugged in may result in electrocution and damage to the device.
    • Hold the hair dryer by the handle so that the back panel faces up.
    FixBot'a Sor
    Yorum Ekle
  2. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: adım 2, 2 resimden 1. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: adım 2, 2 resimden 2.
    • Remove the two 15.875 mm Phillips #2 screws from the back panel.
    FixBot'a Sor
    Yorum Ekle
  3. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: adım 3, 3 resimden 1. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: adım 3, 3 resimden 2. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: adım 3, 3 resimden 3.
    • Starting from where the cord attaches to the handle, pull apart the two plastic panels.
    • Continue separating the back panel, working along the seam.
    • With moderate force, completely remove the back panel from the hair dryer.
    FixBot'a Sor
    Yorum Ekle
  4. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement, Fan Motor Assembly: adım 4, 2 resimden 1. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement, Fan Motor Assembly: adım 4, 2 resimden 2.
    • Hold the hair dryer by the nozzle so that the handle points to the left.
    • Remove the two 1-inch Phillips #2 screws from the back of the fan motor.
    FixBot'a Sor
    Yorum Ekle
  5. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: adım 5, 3 resimden 1. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: adım 5, 3 resimden 2. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: adım 5, 3 resimden 3.
    • Caution: If you recently used the hair dryer, wait at least 10 minutes before attempting this step. The heating element may still be very hot and can cause serious burns.
    • Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
    • Lift the attached electrical wiring and heat shield completely out of the hair dryer.
    FixBot'a Sor
    Yorum Ekle
  6. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement, Hot/Cold Button: adım 6, 1 resimden 1.
    • Caution: Do not attempt to open or tamper with the capacitor. You may suffer severe electrical shocks.
    • Hold the electrical switches so that the wires are facing upwards.
    FixBot'a Sor
    Yorum Ekle
  7. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: adım 7, 1 resimden 1.
    • Focus on the middle of the three buttons.
    • Desolder the button at the circled locations.
    • To reattach the new button, resolder at the same points. Be sure the wires connect to the correct locations.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Timothy Lo
1.214 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-58, Amido Spring 2014 Cal Poly, Team 10-58, Amido Spring 2014 üyesi
CPSU-AMIDO-S14S10G58
4 Üyeler
14 adet Kılavuz yazıldı
2Kılavuz Yorumları
so where do you buy parts???
akatser1 - Yanıt Paylaş
That's not a capacitor, that's an ion generator like this one https://www.goldmine-elec-products.com/p...
Shannon Carey - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 46
Her zaman: 5,274
