Ana içeriğe geç
Contixo V8 Battery Replacement
Neye ihtiyacın var
  1. Contixo V8 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Find the edge of the tablet, where the front panel meets the sides. Use the plastic opening tools to pry the panels apart.
    • The back and front of the device can be reattached by lining them up and pushing around the edges. Be sure to do this around the full perimeter of the device to ensure proper connection. You will hear a popping sound; this is the plastic sliding back into place, and is normal.
    • Lift the face of the tablet.
    FixBot'a Sor
    Yorum Ekle
  2. Contixo V8 Battery Replacement: adım 2, 1 resimden 1.
    • Use the spudger tool to separate the battery from metal screen frame; there will be a small strip of double-sided tape holding it in place. A blue iFixit opening tool would also work for this purpose.
    FixBot'a Sor
    Yorum Ekle
  3. Contixo V8 Battery Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Press the soldering tip to the 3 connection points to detach the motherboard and the battery. See this guide for information and tips on soldering and desoldering.
    • You will need to reattach these connection points when reassembling your device with the soldering iron. This guide will walk you through how to do that. Be sure to attach the positive and negative wires to the correct connections.
    • Exercise caution when desoldering the battery, especially if you've had issues with the device's power which could point to it being faulty. Consider using an anti-static wrist strap when working with the battery and its cables. See this guide for information on swollen batteries, another thing to look out for.
    • The battery is now disconnected and ready to be replaced.
    FixBot'a Sor
    Yorum Ekle
Sonuç
phil_sc_03
231 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 47
Her zaman: 1,144
