Ana içeriğe geç
Cooler Master Laptop Fan Replacement
Neye ihtiyacın var
  1. Cooler Master Laptop Fan Replacement, Fan: adım 1, 1 resimden 1.
    • Set your laptop cooler on the table and make sure it is not plugged into a laptop or powered on.
    • Never try to open the cooler while plugged in.
  2. Cooler Master Laptop Fan Replacement: adım 2, 1 resimden 1.
    • Flip the Device over and find ten folded metal slots holding the metal cover onto the base.
  3. Cooler Master Laptop Fan Replacement: adım 3, 3 resimden 1. Cooler Master Laptop Fan Replacement: adım 3, 3 resimden 2. Cooler Master Laptop Fan Replacement: adım 3, 3 resimden 3.
    • Bend each metal flap straight up with the pliers to allow the metal cover to slide off.
  4. Cooler Master Laptop Fan Replacement: adım 4, 2 resimden 1. Cooler Master Laptop Fan Replacement: adım 4, 2 resimden 2.
    • Remove the cover and expose the inside of the Cooler.
  5. Cooler Master Laptop Fan Replacement: adım 5, 2 resimden 1. Cooler Master Laptop Fan Replacement: adım 5, 2 resimden 2.
    • Unplug the power cable to the fan.
    • Make sure not to apply too much force and disconnect the wires to the device.
  6. Cooler Master Laptop Fan Replacement: adım 6, 2 resimden 1. Cooler Master Laptop Fan Replacement: adım 6, 2 resimden 2.
    • On the bottom of the base locate the screw holes under the sticker on the base.
    • Unscrew the three fan screws.
  7. Cooler Master Laptop Fan Replacement: adım 7, 1 resimden 1.
    • Once all the pieces are taken apart, set aside the old fan and prep the new one for installation.
  8. Cooler Master Laptop Fan Replacement: adım 8, 1 resimden 1.
    • Apply a small amount of thermal compound to the base where the fan sets.
    • Make sure to apply thermal compound to keep the fan from overheating and damaging the base.
  9. Cooler Master Laptop Fan Replacement: adım 9, 2 resimden 1. Cooler Master Laptop Fan Replacement: adım 9, 2 resimden 2.
    • Connect power cable for the fan and place the cables back in their slots.
  10. Cooler Master Laptop Fan Replacement: adım 10, 2 resimden 1. Cooler Master Laptop Fan Replacement: adım 10, 2 resimden 2.
    • Screw fan back onto base.
  11. Cooler Master Laptop Fan Replacement: adım 11, 1 resimden 1.
    • Place cover back on base.
  12. Cooler Master Laptop Fan Replacement: adım 12, 1 resimden 1.
    • Fold all metal flaps back to hold cover on base.
  13. Cooler Master Laptop Fan Replacement: adım 13, 1 resimden 1.
    • Flip it over and it's finished.
Sonuç
Plug in the USB to insure proper working condition. And the cooling pad fan replacement is done.
3 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Hi there,
I’ve got a Targus Lap Chill Matt (Laptop Cooling Pad 15 - 17" Laptops) but the USB port had worn out and require a new replacement. Does anyone have any examples on how to replace the UBS port from a Laptop Cooler Pad?
Thanks!
rolly - Yanıt
Hi,
Just wanted to say huge thanks to you for this guideline! I have a Cooler Master Notepal L1 and the fan kept making noises. But now it works totally fine after I was able to open the cover.
Thanks again!
//Parisa
Parisa - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 83
Her zaman: 6,299
