Coolpix S01 The power button won't turn on Replacement
Giriş
1. adıma gitThis guide will show you how to remove the power button in order to replace it.
Neye ihtiyacın var
First make sure the camera is powered off.
Then take the Hex and PH000 bit to remove a 2mm screw on the left side of the camera.
Next, remove the 2mm screw on the right side of the camera.
Bu adımda kullanılan alet:Tweezers$4.99
After the battery is out, remove the gray button bar from the top of the camera with the smallest opening tool.
With the gray bar detached from the camera, turn it upside down. Using the hex and the J000 bit remove the two 1mm screws.
Take the needle nose tweezers to remove the power button.
