Ana içeriğe geç
Corsair Dark Core RGB PRO SE Battery Replacement
Neye ihtiyacın var
  1. Corsair Dark Core RGB PRO SE Battery Replacement, Battery: adım 1, 3 resimden 1. Corsair Dark Core RGB PRO SE Battery Replacement, Battery: adım 1, 3 resimden 2. Corsair Dark Core RGB PRO SE Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Cover the sensor on the bottom of the mouse with your thumb so it doesn't get damaged.
    • Apply heat with a heat gun or blow dryer to the glide pad near your palm.
    • Carefully remove the glide pad with a spudger.
    • Remove the two screws from beneath the glide pad using a T5 Torx screwdriver.
  2. Corsair Dark Core RGB PRO SE Battery Replacement: adım 2, 3 resimden 1. Corsair Dark Core RGB PRO SE Battery Replacement: adım 2, 3 resimden 2. Corsair Dark Core RGB PRO SE Battery Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the palm rest by pulling it outwards.
    • Pull up where the latches are.
    • Take your time and work around the area to avoid snapping the plastic latches
    • Remove the top buttons by using tweezers and pushing the tabs.
  3. Corsair Dark Core RGB PRO SE Battery Replacement: adım 3, 3 resimden 1. Corsair Dark Core RGB PRO SE Battery Replacement: adım 3, 3 resimden 2. Corsair Dark Core RGB PRO SE Battery Replacement: adım 3, 3 resimden 3.
    • Remove the two screws that were underneath the left and right buttons using a Phillips #00 screwdriver.
    • Place the spudger in between the shell and the bottom of the mouse, releasing the latch.
    • Do not try to remove the top shell by pulling it up as it might break the latch.
    • Remove the six screws using a Phillips #00 screwdriver.
  4. Corsair Dark Core RGB PRO SE Battery Replacement: adım 4, 3 resimden 1. Corsair Dark Core RGB PRO SE Battery Replacement: adım 4, 3 resimden 2. Corsair Dark Core RGB PRO SE Battery Replacement: adım 4, 3 resimden 3.
    • Remove the circuit board by pushing the two latches holding it in place in opposite directions.
    • Unplug the ribbon cable by pushing the black connector holding it in place.
    • Disconnect the battery cord by pulling it up.
  5. Corsair Dark Core RGB PRO SE Battery Replacement: adım 5, 1 resimden 1.
    • Remove the battery with a spudger or your fingers.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Where can I buy a spare battery? I don't see them in stores.
Ilya - Yanıt
I found some models that are compatible on Aliexpress
carlus -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 54
Son 30 gün: 200
Her zaman: 3,234
