Giriş
If you have been using your Corsair Dark Core RGB Pro SE mouse for a while and noticed that it's becoming unresponsive or the clicks are not working properly, it could be due to worn-out mouse nano-switches. This guide will provide you with step-by-step instructions on how to replace the mouse nano-switches of your Corsair Dark Core RGB Pro SE.
Neye ihtiyacın var
Use the heat gun on the bottom of the mouse to loosen the glue on the pads.
Remove the two screws from the bottom of the mouse using a T5 Torx screwdriver.
