Ana içeriğe geç
Corsair K100 Air Wireless Key Spring Replacement
Neye ihtiyacın var
    1. Corsair K100 Air Wireless Key Spring Replacement, Key Spring: adım 1, 2 resimden 1. Corsair K100 Air Wireless Key Spring Replacement, Key Spring: adım 1, 2 resimden 2.
      • Use a keycap puller to remove each of the affected keys.
      • If you don't have a keycap puller, you can use an opening tool to remove the keys.
      • Key internals should be exposed, showing a right and left metal wing with a spring in the center.
      FixBot'a Sor
      Yorum Ekle
    2. Corsair K100 Air Wireless Key Spring Replacement: adım 2, 3 resimden 1. Corsair K100 Air Wireless Key Spring Replacement: adım 2, 3 resimden 2. Corsair K100 Air Wireless Key Spring Replacement: adım 2, 3 resimden 3.
      • Remove the spring from both metal wings using metal tweezers.
      • The metal wings may come off when removing the spring. To restore, place right wing first, then left wing, back in the key internals using the metal tweezers.
      FixBot'a Sor
      Yorum Ekle
    3. Corsair K100 Air Wireless Key Spring Replacement: adım 3, 1 resimden 1.
      • The key spring is ready for replacement.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Abigail Zamora
821 İtibar
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 29
Son 30 gün: 99
Her zaman: 197
