Ana içeriğe geç
Corsair Void Pro RGB Speakers Replacement
Neye ihtiyacın var
  1. Corsair Void Pro RGB Speakers Replacement, Earcup: adım 1, 1 resimden 1.
    • Carefully remove earmuff from headphones by getting a grip under the earmuff cushion and peeling up over the lip that keeps it in place.
  2. Corsair Void Pro RGB Speakers Replacement: adım 2, 2 resimden 1. Corsair Void Pro RGB Speakers Replacement: adım 2, 2 resimden 2.
    • Using the Phillips #0 screwdriver, unscrew the seven 6.4 mm screws holding the black speaker cover in place.
    • If you are disassembling the lefthand earfmuff, there will be eight 6.4 mm screws to remove.
  3. Corsair Void Pro RGB Speakers Replacement: adım 3, 2 resimden 1. Corsair Void Pro RGB Speakers Replacement: adım 3, 2 resimden 2.
    • Remove and set aside the black panel, taking care to keep the wires attached.
    • The panel should lift up without much force. If the panel does not budge, carefully use the iFixit plastic opening tool to dislodge the piece.
  4. Corsair Void Pro RGB Speakers Replacement, Speakers: adım 4, 1 resimden 1.
    • Desolder the wire that connects to the speaker.
    • For steps on how to solder, see this helpful guide.
  5. Corsair Void Pro RGB Speakers Replacement: adım 5, 2 resimden 1. Corsair Void Pro RGB Speakers Replacement: adım 5, 2 resimden 2.
    • Use a knife tool as a wedge to remove the speaker and glue in the new speaker.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Gianna Nobili
827 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S9-G13, Maness Spring 2019 Cal Poly, Team S9-G13, Maness Spring 2019 üyesi
CPSU-MANESS-S19S9G13
4 Üyeler
14 adet Kılavuz yazıldı
5 Yorum
Where can i find a new speaker ?
brunodehulster - Yanıt
The speaker listed in the parts, is not the correct speaker. I purchased them and they are NOT a fit.
ksmith - Yanıt
Whats the size of the speaker?
smack2k - Yanıt
The size of the speaker is 50 mm and about 10 mm in depth. I used this speaker in my own repair and it worked well.
noahoryan -
Can u show how to change “Charging Port”??
Jason HKB - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 44
Her zaman: 3,522
