Ana içeriğe geç
Cowin E7 Extension Arm Replacement
Neye ihtiyacın var
  1. Cowin E7 Extension Arm Replacement, Extension Arm: adım 1, 2 resimden 1. Cowin E7 Extension Arm Replacement, Extension Arm: adım 1, 2 resimden 2.
    • Remove four screws from the extension arm using a TR Torx 10 screwdriver.
  2. Cowin E7 Extension Arm Replacement: adım 2, 1 resimden 1.
    • Pull up on the metal clamp.
    • Squeeze the pins on the top and bottom of the side you are trying to remove.
    • This will allow the extension bracket to easily slide out of the metal clamp.
  3. Cowin E7 Extension Arm Replacement: adım 3, 1 resimden 1.
    • Replace the damaged extension bracket with a new one.
    • To insert the new bracket, remember to squeeze the pins on the side that inserts into the metal clamp.
Sonuç
Jacob Burrer
439 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-2, Mellen Spring 2022 UMass Dartmouth, Team 2-2, Mellen Spring 2022 üyesi
UMASSD-MELLEN-S22S2G2
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 747
