Ana içeriğe geç
Cracked Grout Replacement
Neye ihtiyacın var
  1. Cracked Grout Replacement, Cracked Grout: adım 1, 2 resimden 1. Cracked Grout Replacement, Cracked Grout: adım 1, 2 resimden 2.
    • Identify the crack you will be repairing.
    • Surround it with Painters Tape.
  2. Cracked Grout Replacement: adım 2, 1 resimden 1.
    • Wear protective eye wear and a mask to shield yourself from dust and debris.
    • Use caution when handling the concrete grinder. If handled improperly it can lead to an injury.
    • Use the concrete grinder to remove the grout surrounded with tape where the crack is located.
  3. Cracked Grout Replacement: adım 3, 2 resimden 1. Cracked Grout Replacement: adım 3, 2 resimden 2.
    • Go in with your handheld grout remover and scrape out the remaining grout between the tile until it is completely hollow.
  4. Cracked Grout Replacement: adım 4, 2 resimden 1. Cracked Grout Replacement: adım 4, 2 resimden 2.
    • Vacuum the dust and grout that was removed to reveal a clean and hollow space.
  5. Cracked Grout Replacement: adım 5, 1 resimden 1.
    • Color match your grout by using grout samples to get your desired color of grout.
  6. Cracked Grout Replacement: adım 6, 3 resimden 1. Cracked Grout Replacement: adım 6, 3 resimden 2. Cracked Grout Replacement: adım 6, 3 resimden 3.
    • Mix a scoop of grout and sealer to create a paste.
  7. Cracked Grout Replacement: adım 7, 3 resimden 1. Cracked Grout Replacement: adım 7, 3 resimden 2. Cracked Grout Replacement: adım 7, 3 resimden 3.
    • Take the rubber grout float and press the grout paste securely into the crack.
  8. Cracked Grout Replacement: adım 8, 2 resimden 1. Cracked Grout Replacement: adım 8, 2 resimden 2.
    • Take the grouting sponge and smooth out the grout evenly.
    • Let the grout sit and harden for twenty-four hours.
  9. Cracked Grout Replacement: adım 9, 1 resimden 1.
    • Your new grout is dry and ready for use.
Sonuç
To repair any other cracks in grout, repeat these steps.
8 farklı kişi bu kılavuzu tamamladı.
Deanna Demydyak
456 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
Excelente 👌
Superman07 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 74
Son 30 gün: 354
Her zaman: 7,978
