Ana içeriğe geç
Cracked Grout Replacement
Görüntüleme: 11 B
İstatistikleri görüntüle:
Son 24 Saat:
9
Son 7 Gün:
65
Son 30 Gün:
317
Her zaman:
11.292
Yorumlar: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Tamamlandı: 11
11 kişi bu kılavuzu "tamamlandı" olarak işaretledi. Sıradaki sen olacak mısın?
Sık Kullanılanlar: 3
3 kişi bu kılavuzu favorilerine ekledi (ve abone oldu). Sıradaki sen olacak mısın?
Gerekli Süre: 1 gün
Zorluk: Orta
Öne Çıkan Öğrenci Kılavuzu
Bu kılavuz, çalışkan öğrencilerimizin alın teriyle üretildi ve iFixit kadrosu tarafından epey havalı bulunuyor.
Over time as a result of aging and other factors such as the original installment of the grout, climate, temperature, etc. your grout may begin to crack. With the right tools and direction, it is possible to repair these minor damages in the grout on your own. This guide will provide you with the instructions and tools to repairing these cracks in the grout. The tools listed in this guide are not common household items and can either be bought or rented. They are recommended to be used with protective eye wear and a mask to protect from dust and debris.
Neye ihtiyacın var
    1. Cracked Grout Replacement, Cracked Grout: adım 1, 2 resimden 1. Cracked Grout Replacement, Cracked Grout: adım 1, 2 resimden 2.
      • Identify the crack you will be repairing.
      • Surround it with Painters Tape.
      FixBot'a Sor
      Yorum Ekle
    2. Cracked Grout Replacement: adım 2, 1 resimden 1.
      • Wear protective eye wear and a mask to shield yourself from dust and debris.
      • Use caution when handling the concrete grinder. If handled improperly it can lead to an injury.
      • Use the concrete grinder to remove the grout surrounded with tape where the crack is located.
      FixBot'a Sor
      Yorum Ekle
    3. Cracked Grout Replacement: adım 3, 2 resimden 1. Cracked Grout Replacement: adım 3, 2 resimden 2.
      • Go in with your handheld grout remover and scrape out the remaining grout between the tile until it is completely hollow.
      FixBot'a Sor
      Yorum Ekle
    4. Cracked Grout Replacement: adım 4, 2 resimden 1. Cracked Grout Replacement: adım 4, 2 resimden 2.
      • Vacuum the dust and grout that was removed to reveal a clean and hollow space.
      FixBot'a Sor
      Yorum Ekle
    5. Cracked Grout Replacement: adım 5, 1 resimden 1.
      • Color match your grout by using grout samples to get your desired color of grout.
      FixBot'a Sor
      Yorum Ekle
    6. Cracked Grout Replacement: adım 6, 3 resimden 1. Cracked Grout Replacement: adım 6, 3 resimden 2. Cracked Grout Replacement: adım 6, 3 resimden 3.
      • Mix a scoop of grout and sealer to create a paste.
      FixBot'a Sor
      Yorum Ekle
    7. Cracked Grout Replacement: adım 7, 3 resimden 1. Cracked Grout Replacement: adım 7, 3 resimden 2. Cracked Grout Replacement: adım 7, 3 resimden 3.
      • Take the rubber grout float and press the grout paste securely into the crack.
      FixBot'a Sor
      Yorum Ekle
    8. Cracked Grout Replacement: adım 8, 2 resimden 1. Cracked Grout Replacement: adım 8, 2 resimden 2.
      • Take the grouting sponge and smooth out the grout evenly.
      • Let the grout sit and harden for twenty-four hours.
      FixBot'a Sor
      Yorum Ekle
    9. Cracked Grout Replacement: adım 9, 1 resimden 1.
      • Your new grout is dry and ready for use.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To repair any other cracks in grout, repeat these steps.
11 farklı kişi bu kılavuzu tamamladı.
Deanna Demydyak
546 İtibar
1 Kılavuz yazıldı
Ekip
1Rehber Yorum
Excelente 👌
Superman07 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 65
Son 30 gün: 317
Her zaman: 11,292
