Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Identify the crack you will be repairing.
Surround it with Painters Tape.
Use the concrete grinder to remove the grout surrounded with tape where the crack is located.
Go in with your handheld grout remover and scrape out the remaining grout between the tile until it is completely hollow.
Vacuum the dust and grout that was removed to reveal a clean and hollow space.
Color match your grout by using grout samples to get your desired color of grout.
Take the rubber grout float and press the grout paste securely into the crack.
Take the grouting sponge and smooth out the grout evenly.
Let the grout sit and harden for twenty-four hours.
7 farklı kişi bu kılavuzu tamamladı.
