Ana içeriğe geç
Creative Zen V Plus Charging Port Replacement
Neye ihtiyacın var
  1. Creative Zen V Plus Charging Port Replacement, Prerequisite Only: adım 1, 1 resimden 1.
    • Find the grooves around the buttons on the front and carefully remove the panel. This can be done without the use of any tools.
  2. Creative Zen V Plus Charging Port Replacement: adım 2, 1 resimden 1.
    • Using a plastic opening tool, place the skinny flat end between the groove running along side of the device.
    • Using a twisting motion, detach the control panel from the device
  3. Creative Zen V Plus Charging Port Replacement: adım 3, 1 resimden 1.
    • Find the groove around the outside of the green section. Use an ESD safe spudger to slowly lift the plastic panel up.
  4. Creative Zen V Plus Charging Port Replacement: adım 4, 2 resimden 1. Creative Zen V Plus Charging Port Replacement: adım 4, 2 resimden 2.
    • After removing the green section, find the groove around the display. Insert a ESD safe spudger and carefully lift the display.
  5. Creative Zen V Plus Charging Port Replacement: adım 5, 1 resimden 1.
    • The display can lift up the display but be sure not to damage any of the cables connecting it to the mother board.
    • Remove the screw located under the display using the 00 Phillips head screwdriver.
  6. Creative Zen V Plus Charging Port Replacement: adım 6, 3 resimden 1. Creative Zen V Plus Charging Port Replacement: adım 6, 3 resimden 2. Creative Zen V Plus Charging Port Replacement: adım 6, 3 resimden 3.
    • Pull up on the motherboard and display. It is glued to the base so it will require a little force. Be careful though, as the board is fragile.
  7. Creative Zen V Plus Charging Port Replacement, Charging Port: adım 7, 1 resimden 1.
    • Locate the charging port on the logic board. Around the base of the rectangular port you will find the circles of metal that were used to solder the port to the board. De-solder these circles and remove the port.
    • Learn how to solder and desolder components with this guide!
Sonuç
Bir başkası bu kılavuzu tamamladı.
Joshua Meines
316 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-5, Baechle Fall 2016 IUPUI, Team 2-5, Baechle Fall 2016 üyesi
IUPUI-BAECHLE-F16S2G5
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 269
