Ana içeriğe geç
Crosley CR42 Band Replacement
Neye ihtiyacın var
  1. Crosley CR42  Band Replacement, Band: adım 1, 1 resimden 1.
    • Check troubleshooting wiki to make sure you aren't doing way more work than you have to!
    • If you believe the band may be broken or out of place, start by unplugging the record player.
    FixBot'a Sor
    Yorum Ekle
  2. Crosley CR42  Band Replacement: adım 2, 2 resimden 1. Crosley CR42  Band Replacement: adım 2, 2 resimden 2.
    • Make sure the needle is in its resting position off to the side.
    • Gently remove the turntable from the device by lifting it directly upward.
    FixBot'a Sor
    Yorum Ekle
  3. Crosley CR42  Band Replacement: adım 3, 1 resimden 1.
    • Find the band, it may have fallen into the inside of the record player as you removed the turntable.
    • Inspect your band for any tears, rips, or obvious signs of stretching.
    FixBot'a Sor
    Yorum Ekle
  4. Crosley CR42  Band Replacement: adım 4, 1 resimden 1.
    • Flip the turntable over.
    • Locate the notch on the back side of the turntable.
    • The notch will be on the outside edge of the turntable.
    FixBot'a Sor
    Yorum Ekle
  5. Crosley CR42  Band Replacement: adım 5, 2 resimden 1. Crosley CR42  Band Replacement: adım 5, 2 resimden 2.
    • Wrap the band around the inner circle of the turntable and gently pull the band until you get to the notch.
    • Loop the band around the notch, the band should be taut.
    FixBot'a Sor
    Yorum Ekle
  6. Crosley CR42  Band Replacement: adım 6, 2 resimden 1. Crosley CR42  Band Replacement: adım 6, 2 resimden 2.
    • Place the turntable back onto the device.
    • Make sure to line up the band with the turning knob, to ensure the band is properly placed.
    FixBot'a Sor
    Yorum Ekle
  7. Crosley CR42  Band Replacement: adım 7, 1 resimden 1.
    • After the turntable is back on the device, gently turn it clockwise until you hear a 'click.'
    • Job well done!
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
Roberto Rosila
328 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-38, Maness Winter 2014 Cal Poly, Team 1-38, Maness Winter 2014 üyesi
CPSU-MANESS-W14S1G38
4 Üyeler
5 adet Kılavuz yazıldı
1Rehber Yorum
My CR42 has a plastic piece that will not let me simply pull the turntable off. I don't want to try to hard to break it, but I also don't know how to get it off to replace the band.
athena - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 66
Her zaman: 5,802
