Ana içeriğe geç
Crosley CR42 Power Cable Replacement
Eric Dybsetter
Eric Dybsetter ve 7 diğer katkıda bulunanlar
En son February 25, 2016 tarihinde güncellendi
10 - 30 dakika
Orta
This tutorial will provide the necessary information on how to replace a power cable in the Crosley CR42.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Crosley CR42 Power Cable Replacement, Power Cable: adım 1, 2 resimden 1. Crosley CR42 Power Cable Replacement, Power Cable: adım 1, 2 resimden 2.
    • Turn the device around until you are looking at the line-out port.
    • With a cordless drill or Phillips #0 screwdriver, remove the ten 12-mm screws.
  2. Crosley CR42 Power Cable Replacement: adım 2, 3 resimden 1. Crosley CR42 Power Cable Replacement: adım 2, 3 resimden 2. Crosley CR42 Power Cable Replacement: adım 2, 3 resimden 3.
    • Gently remove the back of the device. It should be connected by two wires.
  3. Crosley CR42 Power Cable Replacement: adım 3, 3 resimden 1. Crosley CR42 Power Cable Replacement: adım 3, 3 resimden 2. Crosley CR42 Power Cable Replacement: adım 3, 3 resimden 3.
    • Gently remove both wires.
    • After de-threading the antenna wire, remove the back of the device and set it aside.
  4. Crosley CR42 Power Cable Replacement: adım 4, 3 resimden 1. Crosley CR42 Power Cable Replacement: adım 4, 3 resimden 2. Crosley CR42 Power Cable Replacement: adım 4, 3 resimden 3.
    • Locate where the power cable connects to the device.
    • Pick up the device and locate the screw holding the small black peg to the device. Unscrew it and set the screw aside.
  5. Crosley CR42 Power Cable Replacement: adım 5, 3 resimden 1. Crosley CR42 Power Cable Replacement: adım 5, 3 resimden 2. Crosley CR42 Power Cable Replacement: adım 5, 3 resimden 3.
    • With the pliers, remove the wire connectors. You may need to be forceful
    • It is wise to attach a marking in order to recognize how the wires should be reattached.
  6. Crosley CR42 Power Cable Replacement: adım 6, 3 resimden 1. Crosley CR42 Power Cable Replacement: adım 6, 3 resimden 2. Crosley CR42 Power Cable Replacement: adım 6, 3 resimden 3.
    • Pull apart both groups of wires.
    • After getting your replacement power cord, make sure you recognize how the wires should reattach.
  7. Crosley CR42 Power Cable Replacement: adım 7, 3 resimden 1. Crosley CR42 Power Cable Replacement: adım 7, 3 resimden 2. Crosley CR42 Power Cable Replacement: adım 7, 3 resimden 3.
    • Twist the connecting wires together.
    • Attach the twist-on wire connectors to the exposed wires.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Eric Dybsetter
193 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 1-38, Maness Winter 2014 Cal Poly, Team 1-38, Maness Winter 2014 üyesi
CPSU-MANESS-W14S1G38
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 6,493
