Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Cut around the seam of the crown molding with a knife or razor blade.
Gently pry the molding from the wall using a flat prying tool such as a putty knife.
Work the putty knife back and further along the seams to gradually pry the molding from the wall.
Remove old nails, caulk, or adhesives from the wall and/or molding.
Fill in holes created from nails with wood glue or adhesive.
Identify splits or cracks that are within the scope of repair.
If possible, place the nozzle underneath the split or crack and apply adhesive.
Remove any excess adhesive.
Caulk the seams of the trim to make a clean transition between wall, ceiling, and adjacent trim.
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Hello Merrick Juarez
sir can you guide me on which glue I select from these all top 10 types of glue for furniture and Crown Molding Trim Replacement I have been read your all instructions but not clear about such glue which I use for the project. I have facing trouble in selecting the right glue for wood
For a project like this, I suggest using any brand of wood glue. You can find these products at Home Depot, Lowes, or other similar stores. It does not matter which brand you buy. Just make sure the product is made for wood, and that you read the instructions on the product that you buy for the required cure times. I hope this helps.
