Ana içeriğe geç
CrystalView NB4-35788 Battery Replacement
Neye ihtiyacın var
  1. CrystalView NB4-35788 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Power off the device before beginning disassembly.
    • Using a Phillips #00 Screwdriver, take out the following screws:
    • Two 6 mm screws
    • Three 4 mm screws
    • Four 3 mm screws
    • These screws can be taken out in any order.
  2. CrystalView NB4-35788 Battery Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #00 Screwdriver, remove the screws located under the top two standoffs.
  3. CrystalView NB4-35788 Battery Replacement: adım 3, 1 resimden 1.
    • Remove the cover off the back of the device.
  4. CrystalView NB4-35788 Battery Replacement: adım 4, 1 resimden 1.
    • Remove the battery using a plastic spudger.
    • Do not use a metal spudger, as this can damage the device.
  5. CrystalView NB4-35788 Battery Replacement: adım 5, 2 resimden 1. CrystalView NB4-35788 Battery Replacement: adım 5, 2 resimden 2.
    • Peel back the yellow film on the old battery to expose the red and black wires
    • De-solder these wires to disconnect the old battery
    • Be careful while using a soldering iron as it is extremely hot.
    • Follow the How To Solder and Desolder Connections guide for help.
Sonuç
Courtney Clark
218 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 312
