Ana içeriğe geç
Cuisinart DFP-14BCN Switch Replacement
Neye ihtiyacın var
  1. Cuisinart DFP-14BCN Switch Replacement, Bowl: adım 1, 3 resimden 1. Cuisinart DFP-14BCN Switch Replacement, Bowl: adım 1, 3 resimden 2. Cuisinart DFP-14BCN Switch Replacement, Bowl: adım 1, 3 resimden 3.
    • Unplug your food processor before starting any disassembly.
    • Remove the small pusher by rotating it clockwise and lifting up.
  2. Cuisinart DFP-14BCN Switch Replacement: adım 2, 1 resimden 1.
    • Remove the large pusher by grabbing its sides and pulling up.
    • There may be a clicking sound from the safety feature being disengaged in this step.
  3. Cuisinart DFP-14BCN Switch Replacement: adım 3, 3 resimden 1. Cuisinart DFP-14BCN Switch Replacement: adım 3, 3 resimden 2. Cuisinart DFP-14BCN Switch Replacement: adım 3, 3 resimden 3.
    • Remove the lid from the bowl by turning it clockwise and lifting.
  4. Cuisinart DFP-14BCN Switch Replacement: adım 4, 1 resimden 1.
    • Take out the blades by grabbing the plastic center piece and lifting up.
    • Avoid contact with blades as they are extremely sharp.
  5. Cuisinart DFP-14BCN Switch Replacement: adım 5, 3 resimden 1. Cuisinart DFP-14BCN Switch Replacement: adım 5, 3 resimden 2. Cuisinart DFP-14BCN Switch Replacement: adım 5, 3 resimden 3.
    • Position the handle of the bowl so that it is on your left.
    • Grab the handle and push clockwise. Lift up the bowl to remove it.
  6. Cuisinart DFP-14BCN Switch Replacement, Back Casing: adım 6, 2 resimden 1. Cuisinart DFP-14BCN Switch Replacement, Back Casing: adım 6, 2 resimden 2.
    • Turn the food processor's base upside down by lifting it up and turning it over.
    • Position the base so that the on and pulse buttons are facing you.
    • Place the base on top of the food processor's bowl to keep the base from wobbling while you work on it.
  7. Cuisinart DFP-14BCN Switch Replacement: adım 7, 2 resimden 1. Cuisinart DFP-14BCN Switch Replacement: adım 7, 2 resimden 2.
    • Remove the two 13.0mm screws that hold down the casing with a Phillips #2 screwdriver.
  8. Cuisinart DFP-14BCN Switch Replacement: adım 8, 3 resimden 1. Cuisinart DFP-14BCN Switch Replacement: adım 8, 3 resimden 2. Cuisinart DFP-14BCN Switch Replacement: adım 8, 3 resimden 3.
    • Lift up the front left and the back right rubber feet by pulling back the rubber with your fingers.
    • Remove the 13.0mm screw under each rubber foot with a Phillips #2 screwdriver.
  9. Cuisinart DFP-14BCN Switch Replacement: adım 9, 2 resimden 1. Cuisinart DFP-14BCN Switch Replacement: adım 9, 2 resimden 2.
    • Lift off the back casing by raising it upward.
  10. Cuisinart DFP-14BCN Switch Replacement, Buttons: adım 10, 3 resimden 1. Cuisinart DFP-14BCN Switch Replacement, Buttons: adım 10, 3 resimden 2. Cuisinart DFP-14BCN Switch Replacement, Buttons: adım 10, 3 resimden 3.
    • Remove the two 13.0mm screws that are holding down the button assembly using the Phillips #2 screwdriver.
  11. Cuisinart DFP-14BCN Switch Replacement: adım 11, 2 resimden 1. Cuisinart DFP-14BCN Switch Replacement: adım 11, 2 resimden 2.
    • Lift out the button assembly by pulling up.
  12. Cuisinart DFP-14BCN Switch Replacement: adım 12, 1 resimden 1.
    • Remove the two 5.5mm nuts with a 5.5mm nut driver.
  13. Cuisinart DFP-14BCN Switch Replacement: adım 13, 3 resimden 1. Cuisinart DFP-14BCN Switch Replacement: adım 13, 3 resimden 2. Cuisinart DFP-14BCN Switch Replacement: adım 13, 3 resimden 3.
    • Remove the two 13.0mm screws that hold the switch to the button assembly with a Phillips #2 screwdriver.
    • The screws have glue in their threads, so this step might require a little extra force.
    • Slide off the switch and yellow plastic to remove the button assembly.
  14. Cuisinart DFP-14BCN Switch Replacement, Switch: adım 14, 2 resimden 1. Cuisinart DFP-14BCN Switch Replacement, Switch: adım 14, 2 resimden 2.
    • Desolder the white, black and red connections from the switch by using a soldering iron.
    • Refer to the soldering guide for extra help.
    • For reassembly, the new switch's connections will have to be soldered on.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sonya Dick
352 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-3, Livingston Fall 2016 Cal Poly, Team 10-3, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S10G3
3 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
You had me until the desoldering, maybe I’m just a wimp! Thanks anyway … good description!
dmdudek - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 37
Her zaman: 1,609
