Ana içeriğe geç
Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement
Neye ihtiyacın var
  1. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement, Power Cord: adım 1, 1 resimden 1.
    • Use a screwdriver to remove the four screws that are next to the grip pads on the bottom of the motor base.
  2. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: adım 2, 1 resimden 1.
    • Remove the black plastic covering from the motor base.
  3. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: adım 3, 1 resimden 1.
    • Locate the connections between the power cord and the brown and white wires. Cut off these connections.
  4. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: adım 4, 1 resimden 1.
    • Strip the plastic coating off the edge of the brown and white wires using a wire stripper.
  5. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: adım 5, 1 resimden 1.
    • Create a connection between the brown and white wires and the wires of the new power cord by soldering them together.
  6. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: adım 6, 1 resimden 1.
    • Fit the wires back into the motor base and place the new power cord in the slot.
Sonuç
By the end of this guide< you will have successfully replaced the power cord to your device.
Bir başkası bu kılavuzu tamamladı.
Reagan Burns
119 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 24-1, Lancaster Spring 2015 Cal Poly, Team 24-1, Lancaster Spring 2015 üyesi
CPSU-LANCASTER-S15S24G1
2 Üyeler
1 Kılavuz yazıldı
4 Yorum
I can't get a replacement cord from cuisinart. Where can I buy one the same?
Elizabeth - Yanıt
I need one also. drshtender1@gmail.com
Feivel Garnick -
Where can you buy the replacement cord?
ruby48lp - Yanıt
There's not an exact replacement from Cuisinart, but a two prong replacement will work. I found one "Lamp Cord Set - Black - PLT 56-1854-50 | 1000Bulbs.com" https://www.1000bulbs.com/product/137344... that would work.
Riley Carns - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 19
Her zaman: 1,673
