Ana içeriğe geç
Curtain Rod Bracket Replacement
Neye ihtiyacın var
  1. Curtain Rod Bracket Replacement, Bracket: adım 1, 2 resimden 1. Curtain Rod Bracket Replacement, Bracket: adım 1, 2 resimden 2.
    • If the bracket is still partially attached, use a screwdriver to remove the remaining screw(s), then remove the bracket from the wall completely.
  2. Curtain Rod Bracket Replacement: adım 2, 2 resimden 1. Curtain Rod Bracket Replacement: adım 2, 2 resimden 2.
    • Observe the hole of the screw(s) that was ripped out of the wall.
    • Determine whether the plastic anchor will fit in the current size of the hole.
    • If the hole is smaller than the anchor, continue to Step 3. If the hole is bigger, complete this guide on patching a hole in dry wall.
  3. Curtain Rod Bracket Replacement: adım 3, 2 resimden 1. Curtain Rod Bracket Replacement: adım 3, 2 resimden 2.
    • Use a ¼ inch drill bit to drill the hole(s) that the anchor will be placed into. Drill into the wall and continue drilling as you pull out of the wall.
    • Avoid placing hands near the drill bit while in use. If you have medium to long-length hair, tie your hair back to avoid possible injury.
  4. Curtain Rod Bracket Replacement: adım 4, 3 resimden 1. Curtain Rod Bracket Replacement: adım 4, 3 resimden 2. Curtain Rod Bracket Replacement: adım 4, 3 resimden 3.
    • Hammer the hollow wall anchor(s) into the hole until flush with the drywall.
  5. Curtain Rod Bracket Replacement: adım 5, 1 resimden 1.
    • Paint the wall anchor and any surrounding area that has been damaged so that it matches the wall.
  6. Curtain Rod Bracket Replacement: adım 6, 2 resimden 1. Curtain Rod Bracket Replacement: adım 6, 2 resimden 2.
    • Screw the bracket into the anchor(s) with a screwdriver. The bracket will be secured to the wall.
  7. Curtain Rod Bracket Replacement: adım 7, 2 resimden 1. Curtain Rod Bracket Replacement: adım 7, 2 resimden 2.
    • Touch up with paint if necessary.
  8. Curtain Rod Bracket Replacement: adım 8, 2 resimden 1. Curtain Rod Bracket Replacement: adım 8, 2 resimden 2.
    • Rehang your curtain rod and curtains by placing the rod onto the bracket.
Sonuç
Enjoy your renewed privacy!
Ashtyn Drake
157 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 19
Son 30 gün: 67
Her zaman: 1,354
