Ana içeriğe geç
D-Link DIR-890L Power Switch Replacement
Neye ihtiyacın var
  1. D-Link DIR-890L Power Switch Replacement, Case: adım 1, 3 resimden 1. D-Link DIR-890L Power Switch Replacement, Case: adım 1, 3 resimden 2. D-Link DIR-890L Power Switch Replacement, Case: adım 1, 3 resimden 3.
    • Peel off the four rubber rectangular feet with your fingers.
    • The feet may be hard to remove. Apply additional force if necessary.
  2. D-Link DIR-890L Power Switch Replacement: adım 2, 3 resimden 1. D-Link DIR-890L Power Switch Replacement: adım 2, 3 resimden 2. D-Link DIR-890L Power Switch Replacement: adım 2, 3 resimden 3.
    • Unscrew the 5mm screws in each corner using the Phillips #1 screwdriver.
  3. D-Link DIR-890L Power Switch Replacement: adım 3, 3 resimden 1. D-Link DIR-890L Power Switch Replacement: adım 3, 3 resimden 2. D-Link DIR-890L Power Switch Replacement: adım 3, 3 resimden 3.
    • Wedge the opening tool between the red top panel and the gray bottom panel.
    • Twist the opening tool to separate the panels. Work your way around the case until both of the panels are separated.
  4. D-Link DIR-890L Power Switch Replacement, Motherboard: adım 4, 1 resimden 1.
    • Orient the router so the narrow end of the router faces you and the ports face away from you.
    • The six, hot-glued antenna connections are in the middle and at the top right of the motherboard.
  5. D-Link DIR-890L Power Switch Replacement: adım 5, 3 resimden 1. D-Link DIR-890L Power Switch Replacement: adım 5, 3 resimden 2. D-Link DIR-890L Power Switch Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Heavy-Duty Spudger
  6. D-Link DIR-890L Power Switch Replacement: adım 6, 2 resimden 1. D-Link DIR-890L Power Switch Replacement: adım 6, 2 resimden 2.
    • Continue to pry off the last three antenna connections on the upper right portion of the motherboard.
  7. D-Link DIR-890L Power Switch Replacement: adım 7, 3 resimden 1. D-Link DIR-890L Power Switch Replacement: adım 7, 3 resimden 2. D-Link DIR-890L Power Switch Replacement: adım 7, 3 resimden 3.
    • Open the plastic bracket enclosing the three antenna wires and pull the wires out with your hands.
  8. D-Link DIR-890L Power Switch Replacement: adım 8, 3 resimden 1. D-Link DIR-890L Power Switch Replacement: adım 8, 3 resimden 2. D-Link DIR-890L Power Switch Replacement: adım 8, 3 resimden 3.
    • Pull the yellow tape off of the motherboard to release the final antenna wire.
  9. D-Link DIR-890L Power Switch Replacement: adım 9, 2 resimden 1. D-Link DIR-890L Power Switch Replacement: adım 9, 2 resimden 2.
    • Pull the the motherboard away from the case to remove it. Start on the side closest to you, and pull up and out.
  10. D-Link DIR-890L Power Switch Replacement, Power Switch: adım 10, 3 resimden 1. D-Link DIR-890L Power Switch Replacement, Power Switch: adım 10, 3 resimden 2. D-Link DIR-890L Power Switch Replacement, Power Switch: adım 10, 3 resimden 3.
    • Locate the power switch on the top left of the motherboard.
    • The power switch is the component that sticks out the furthest.
    • Turn the motherboard upside down.
    • Locate the 6 solder joints that connect the power switch to the motherboard. They are arranged in 2 columns of 3.
  11. D-Link DIR-890L Power Switch Replacement: adım 11, 2 resimden 1. D-Link DIR-890L Power Switch Replacement: adım 11, 2 resimden 2.
    Desoldering Pump
    $3.99
    • Using a soldering iron and desoldering pump, desolder the power switch from the board.
    • For more information, see this guide on desoldering.
Sonuç
Rachel Shaw
553 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-7, Livingston Fall 2016 Cal Poly, Team 10-7, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S10G7
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 1,244
