Ana içeriğe geç
DJI Mavic Pro Front Vision Replacement
Neye ihtiyacın var
    1. DJI Mavic Pro Front Vision Replacement, Battery: adım 1, 3 resimden 1. DJI Mavic Pro Front Vision Replacement, Battery: adım 1, 3 resimden 2. DJI Mavic Pro Front Vision Replacement, Battery: adım 1, 3 resimden 3.
      • Grab both sides of the battery.
      • Pinch the releasing buttons on both sides of the battery.
      • Lift the battery up and out.
      FixBot'a Sor
      Yorum Ekle
    1. DJI Mavic Pro Front Vision Replacement, Upper Shell: adım 2, 1 resimden 1.
      • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
      FixBot'a Sor
      Yorum Ekle
    2. DJI Mavic Pro Front Vision Replacement: adım 3, 1 resimden 1.
      • Flip the drone over so that the gimbal is facing up.
      • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
      • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
      FixBot'a Sor
      Yorum Ekle
    3. DJI Mavic Pro Front Vision Replacement: adım 4, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Remove the two small panel pieces near the gimbal case with the tweezers.
      FixBot'a Sor
      Yorum Ekle
    4. DJI Mavic Pro Front Vision Replacement: adım 5, 1 resimden 1.
      • Remove the two 5mm 1.5 Hex screws and two PH000 screws that are under the panel pieces by turning the respective screwdrivers counterclockwise.
      FixBot'a Sor
      Yorum Ekle
    5. DJI Mavic Pro Front Vision Replacement: adım 6, 1 resimden 1.
      • Flip the drone back over so the upper shell is facing up.
      • Pry off the upper shell with a nylon spudger.
      • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
      FixBot'a Sor
      Yorum Ekle
    6. DJI Mavic Pro Front Vision Replacement: adım 7, 1 resimden 1.
      • Remove the white connector at the back of the flight controller board by gently pulling at the base.
      FixBot'a Sor
      Yorum Ekle
    1. DJI Mavic Pro Front Vision Replacement, Gimbal/Camera: adım 8, 1 resimden 1.
      • Remove the one 5mm JIS #0 screw from the small micro controller board at the front of the DJI Mavic Pro by turning counterclockwise.
      FixBot'a Sor
      Yorum Ekle
    2. DJI Mavic Pro Front Vision Replacement: adım 9, 1 resimden 1.
      • Pull the cord and micro controller board away from the front of the DJI Mavic Pro using tweezers.
      FixBot'a Sor
      Yorum Ekle
    3. DJI Mavic Pro Front Vision Replacement: adım 10, 2 resimden 1. DJI Mavic Pro Front Vision Replacement: adım 10, 2 resimden 2.
      • Expose the two small ZIF connectors near the front of the board by removing the plastic coverings.
      • Then, remove the two ZIF connectors under the coverings using a nylon spudger.
      FixBot'a Sor
      Yorum Ekle
    4. DJI Mavic Pro Front Vision Replacement: adım 11, 1 resimden 1.
      • Remove two 6mm JIS #00 screws from the plastic board cover at the front of the DJI Mavic Pro.
      FixBot'a Sor
      Yorum Ekle
    5. DJI Mavic Pro Front Vision Replacement: adım 12, 2 resimden 1. DJI Mavic Pro Front Vision Replacement: adım 12, 2 resimden 2.
      • Flip the DJI Mavic Pro over.
      • Gently press the latch for the Gimbal cover.
      • Pull the cover off.
      FixBot'a Sor
      Yorum Ekle
    6. DJI Mavic Pro Front Vision Replacement: adım 13, 2 resimden 1. DJI Mavic Pro Front Vision Replacement: adım 13, 2 resimden 2.
      • Flip the DJI Mavic Pro back over, with its top side facing up.
      • Remove the two ZIF connectors located behind the plastic covers by using a nylon spudger.
      FixBot'a Sor
      Yorum Ekle
    7. DJI Mavic Pro Front Vision Replacement: adım 14, 1 resimden 1.
      • Gently remove the power cable connector located to the left, behind the gimbal board, by pulling up on the white base.
      FixBot'a Sor
      Yorum Ekle
    8. DJI Mavic Pro Front Vision Replacement: adım 15, 1 resimden 1.
      • Scrape away the plastic adhesive covering the two 5mm JIS #000 screws connected to the gimbal board.
      • Remove the two 5mm JIS #000 screws from the gimbal board by turning the screwdriver counterclockwise.
      FixBot'a Sor
      Yorum Ekle
    9. DJI Mavic Pro Front Vision Replacement: adım 16, 1 resimden 1.
      • Remove the two 7mm JIS #00 screws at the very front of the DJI Mavic Pro by turning the screwdriver counterclockwise.
      • Careful when removing these screws the camera or whatever remains of your camera assembly may drop
      FixBot'a Sor
      Yorum Ekle
    10. DJI Mavic Pro Front Vision Replacement: adım 17, 2 resimden 1. DJI Mavic Pro Front Vision Replacement: adım 17, 2 resimden 2.
      • Flip the DJI Mavic Pro over, with the camera facing you.
      • Gently pull the gimbal/camera assembly up and out.
      FixBot'a Sor
      Yorum Ekle
    1. DJI Mavic Pro Front Vision Replacement, Front Vision: adım 18, 1 resimden 1.
      • Remove the two 6mm JIS #0 screws by turning counterclockwise.
      FixBot'a Sor
      Yorum Ekle
    2. DJI Mavic Pro Front Vision Replacement: adım 19, 1 resimden 1.
      • Remove the front vision piece by pulling the piece up and away from the drone body.
      FixBot'a Sor
      Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Kyle Kelser
644 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G3, White Fall 2018 Cal Poly, Team S17-G3, White Fall 2018 üyesi
CPSU-WHITE-F18S17G3
4 Üyeler
72 adet Kılavuz yazıldı
4Kılavuz Yorumları
What error codes did you get before having to replace this front cameras?
Daniel Rubio Rocamora - Yanıt Paylaş
la nacelle de mon drone mavic pro ne fais aucun mouvement quand je l'allume s'il vous plaît quel pourrait être le problème ?
Picharkayo@gmail.com
Pichar Kayo - Yanıt Paylaş
it's most likely the ribbon cable 9-dollar fix from Amazon. that would be my first guess
J. Brown - Yanıt Paylaş
I have error of forward motion isn’t recognizing how can I fix it please help
Aoldmilkman1 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 26
Son 30 gün: 87
Her zaman: 8,782
