DJI Mavic Pro WiFi Board Replacement
Giriş
1. adıma gitThis set of instructions will walk you through how to replace the DJI Mavic Pro WiFi Board. The WiFi board is located under the upper shell of the drone. In order to get to the WiFi board you will need to remove the battery and upper shell first. You will need to carefully pry the upper shell off to perform this guide.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
Grab both sides of the battery.
Pinch the releasing buttons on both sides of the battery.
Lift the battery up and out.
Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
Remove the lone 4mm Phillips #00 screw holding the WiFi board in place by turning the screwdriver counterclockwise.
3 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Are there any connectivity issues, like new passwords etc?
Mine was removed by the former owner and the coaxial connectors were removed at the same time. I bought a new module that has the coaxial wires and one ribbon cable and now I have to see about removing either the bottom of the drone or one of the boards to gain access to where these connectors go to. Is there another video as to how to do that? Several of the hex screws are stripped to the point where my 5mm hex screwdriver don't remove them. Is there a fix for that (stripped screws)?
