Ana içeriğe geç
DJI Mavic Pro WiFi Board Replacement
Neye ihtiyacın var
  1. DJI Mavic Pro WiFi Board Replacement, Battery: adım 1, 3 resimden 1. DJI Mavic Pro WiFi Board Replacement, Battery: adım 1, 3 resimden 2. DJI Mavic Pro WiFi Board Replacement, Battery: adım 1, 3 resimden 3.
    • Grab both sides of the battery.
    • Pinch the releasing buttons on both sides of the battery.
    • Lift the battery up and out.
  2. DJI Mavic Pro WiFi Board Replacement, Upper Shell: adım 2, 1 resimden 1.
    • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
  3. DJI Mavic Pro WiFi Board Replacement: adım 3, 1 resimden 1.
    • Flip the drone over so that the gimbal is facing up.
    • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    the author forgot to mention to remove also the two screws right next to the gimbal. in this picture, they are already removed. without removing these, you cannot open the drone!!
    Joris Ott - Yanıt
    also, the screws above in the red circles are not the same as the ones in step 2 and 5! They are shorter! I don’t know how long but not 5mm!
    Joris Ott - Yanıt
    Yes, please add those screws - almost broke the top case ;-(
    xyz40 - Yanıt
    Screws thinner too.
    Lee Day - Yanıt
    I must preface what I am about to say with this walk-through is amazing! Everything before and after this and the next step is spot-on!
    There needs to be a step in-between this and the next.
    UNDER THOSE CAPS ARE MORE SCREWS!!!
    I pretty much ruined the top case because I missed this and tried to muscle it open for about an hour. Just trying to warn the next.
    Like I've said; this is an amazing walk-through
    DizaBlah - Yanıt
  4. DJI Mavic Pro WiFi Board Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the two small panel pieces near the gimbal case with the tweezers.
    BEWARE! The two screws under the covers are not mentioned in step four to be removed, but they show that they have been removed in step five.
    Patrick Madden - Yanıt
    Step five should read- Remove the SIX 5mm 1.5 Hex screws that are under the panel pieces by turning the screwdriver counterclockwise.
  5. DJI Mavic Pro WiFi Board Replacement: adım 5, 1 resimden 1.
    • Remove the two 5mm 1.5 Hex screws and two PH000 screws that are under the panel pieces by turning the respective screwdrivers counterclockwise.
    You need to remove the 2 screws (as the picture shows) that are adjacent to each side of the gimbal (below the screws circled in the picture. This also connect to the top shell and could cause an issue!
    ellfa1 - Yanıt
    What he said!! ^^^
    shaun.cunningham - Yanıt
    You might notice that there are two crosshead screws with larger heads (top two circled in image). You do NOT need to touch these as they are not part of the gimbal assembly.
    james.collins1905 - Yanıt
    Agree with @elfa1 - do not remove the top two screws, or you will put unnecessary strain on the plastic while moving arms. No need for that at all.
    demanufacturer - Yanıt
  6. DJI Mavic Pro WiFi Board Replacement: adım 6, 1 resimden 1.
    • Flip the drone back over so the upper shell is facing up.
    • Pry off the upper shell with a nylon spudger.
    • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
    using pry tool is not necessary - once all top shell screws are removed you should be able to take the top shell off with your hand.
    KopaZ Maymay - Yanıt
    Sorry “KopaZ Maymay”, aber der Plastiköffner ist “sowas von erforderlich”, weil man sonst leider die beiden Plastiknasen in der Front riskiert.
    Orbiter - Yanıt
    Zudem fehlt hier die Angabe der genauen Lage von beiden vorderen Nasen:
    Sie befinden sich von der Mitte aus gemessen jeweils 9mm nach links und rechts. Der obere Gehäuseteil wird von zwei 5mm breiten Bügeln gehalten, die unter die horizontal nach innen zeigenden Nasen vom unteren Gehäuseteil greifen.
    Orbiter - Yanıt
    Sorry “KopaZ Maymay”, but the plastic opener is “so necessary” because otherwise you unfortunately risk the two plastic noses in the front.
    In addition, the exact position of both front noses is missing in the description:
    They are measured 9mm from the center to the left and right. The upper part of the housing is held by two 5mm wide brackets that grip under the noses pointing horizontally inwards from the lower part of the housing.
    Orbiter - Yanıt
    Hi, is it a simple replacement. Ie you do not have to reprogram? Thanks
    farkin joker - Yanıt
  7. DJI Mavic Pro WiFi Board Replacement: adım 7, 1 resimden 1.
    • Remove the white connector at the back of the flight controller board by gently pulling at the base.
    Hello there, can anyone tell me, please, what type of connector is this? I ruined mine and i like to fixit.
    Ene Alexandru - Yanıt
  8. DJI Mavic Pro WiFi Board Replacement, WiFi Board: adım 8, 1 resimden 1.
    • Remove the lone 4mm Phillips #00 screw holding the WiFi board in place by turning the screwdriver counterclockwise.
  9. DJI Mavic Pro WiFi Board Replacement: adım 9, 1 resimden 1.
    • Remove the two gold coaxial connectors by pulling gently at the base with tweezers.
    die Wifi-Platine hängt an einem weiteren Flachkabel, welches vorher gelöst werden muss. am einfachsten geht es, wenn man den Kühldeckel auf der anderen Seite löst, den Silikonkleber entfernt und es von dort lößt.
    C K - Yanıt
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Mondona Behroozian
1.624 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G3, White Fall 2018 Cal Poly, Team S17-G3, White Fall 2018 üyesi
CPSU-WHITE-F18S17G3
4 Üyeler
14 adet Kılavuz yazıldı
3Kılavuz Yorumları
Is it possible to remove the wifi card completely and fly the drone without it ?
Quentin V - Yanıt
Are there any connectivity issues, like new passwords etc?
Chris Stoll - Yanıt
Mine was removed by the former owner and the coaxial connectors were removed at the same time. I bought a new module that has the coaxial wires and one ribbon cable and now I have to see about removing either the bottom of the drone or one of the boards to gain access to where these connectors go to. Is there another video as to how to do that? Several of the hex screws are stripped to the point where my 5mm hex screwdriver don't remove them. Is there a fix for that (stripped screws)?
Mike Belanger - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 53
Her zaman: 3,617
