Ana içeriğe geç
DJI Mini 2 Main Board Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. DJI Mini 2 Main Board  Replacement, Battery: adım 1, 2 resimden 1. DJI Mini 2 Main Board  Replacement, Battery: adım 1, 2 resimden 2.
    • Face the DJI Mini 2 away from you so that you are looking at the charging ports.
    • Use your finger to open up the back panel.
    FixBot'a Sor
    Yorum Ekle
  2. DJI Mini 2 Main Board  Replacement: adım 2, 2 resimden 1. DJI Mini 2 Main Board  Replacement: adım 2, 2 resimden 2.
    • Pinch the locking mechanism on the battery to release the lock.
    • Pull the battery straight out of the compartment.
    FixBot'a Sor
    Yorum Ekle
  3. DJI Mini 2 Main Board  Replacement, Drone Body: adım 3, 2 resimden 1. DJI Mini 2 Main Board  Replacement, Drone Body: adım 3, 2 resimden 2.
    • Unfold the wings of the drone.
    • Place the drone upside down on a flat surface.
    • There should be stickers on the device telling you how to unfold the propeller arms.
    FixBot'a Sor
    Yorum Ekle
  4. DJI Mini 2 Main Board  Replacement: adım 4, 2 resimden 1. DJI Mini 2 Main Board  Replacement: adım 4, 2 resimden 2.
    • Remove the four 5 mm J000 screws near each propeller arm.
    FixBot'a Sor
    Yorum Ekle
  5. DJI Mini 2 Main Board  Replacement: adım 5, 3 resimden 1. DJI Mini 2 Main Board  Replacement: adım 5, 3 resimden 2. DJI Mini 2 Main Board  Replacement: adım 5, 3 resimden 3.
    • Flip the drone back over.
    • Use a combination of the opening tool and your fingers to pry open the top panel of the drone along the seams.
    FixBot'a Sor
    Yorum Ekle
  6. DJI Mini 2 Main Board  Replacement: adım 6, 2 resimden 1. DJI Mini 2 Main Board  Replacement: adım 6, 2 resimden 2.
    • Remove the two 5 mm J000 screws located in the battery hatch and near the ports on the back of the drone.
    FixBot'a Sor
    Yorum Ekle
  7. DJI Mini 2 Main Board  Replacement: adım 7, 2 resimden 1. DJI Mini 2 Main Board  Replacement: adım 7, 2 resimden 2.
    • Flip the drone over again.
    • Pry off the bottom panel of the drone using the opening tools and your fingers.
    FixBot'a Sor
    Yorum Ekle
  8. DJI Mini 2 Main Board  Replacement, Main Board: adım 8, 3 resimden 1. DJI Mini 2 Main Board  Replacement, Main Board: adım 8, 3 resimden 2. DJI Mini 2 Main Board  Replacement, Main Board: adım 8, 3 resimden 3.
    • Remove the three 3mm J000 screws on the black plate.
    FixBot'a Sor
    Yorum Ekle
  9. DJI Mini 2 Main Board  Replacement: adım 9, 2 resimden 1. DJI Mini 2 Main Board  Replacement: adım 9, 2 resimden 2.
    • Use your fingers to pull the black plate off to reveal main board.
    FixBot'a Sor
    Yorum Ekle
  10. DJI Mini 2 Main Board  Replacement: adım 10, 3 resimden 1. DJI Mini 2 Main Board  Replacement: adım 10, 3 resimden 2. DJI Mini 2 Main Board  Replacement: adım 10, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Try to avoid disturbing the blue thermal paste covering two of the large board components. If the paste is disturbed or splotchy in places it may need to be removed and reapplied. For more information refer to the How to Apply Thermal Paste guide.
    • Using ESD Safe Tweezers Blunt Nose, remove the 5 cables attached to the main board.
    FixBot'a Sor
    Yorum Ekle
  11. DJI Mini 2 Main Board  Replacement: adım 11, 2 resimden 1. DJI Mini 2 Main Board  Replacement: adım 11, 2 resimden 2.
    • Use the ESD Safe Tweezers Blunt Nose and your fingers to pull off the main board from the drone carriage.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Parker Sowersby
322 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team F-1, Gurgel Spring 2022 UMass Dartmouth, Team F-1, Gurgel Spring 2022 üyesi
UMASSD-GURGEL-S22SFG1
2 Üyeler
20 adet Kılavuz yazıldı
2Kılavuz Yorumları
I found this mini 2 post interesting, even if i want to do somthing
different.
my goal is to install the old motherboard in newer hardware...
gimbal. IMU board barometer/compass busted after the super
90 deg DJI off function, because of a gust... crash,'i really
LOVE DJI.....NOT!"
then I ask to buy parts from them, then they babble
about warranty.... nope bro we are not selling parts
forget it we want to repair it.... forget it, it's my drone
i rather sledge hammer it on YouTube.
so this is last resort transplanting a board with old
firmware, I don't want to use a new bird with more stupid
chiness software, that has no real bearing of local aeronautical
laws.
not using them otherwise. goodbye DJI
Do never buy a Chinese drone! From crappy company
might look here again
albi - Yanıt Paylaş
Great advice, thank you.
mauricio vilchez - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 36
Son 30 gün: 222
Her zaman: 9,835
