Ana içeriğe geç
DJI Mini 2 Propeller Blades Replacement
Jacob Matos
Jacob Matos ve başka bir katkıda bulunan
En son May 11, 2022 tarihinde güncellendi
15 - 20 dakika
Kolay
İşlem Görüntüleri
Daha Fazla Görsel Gerekli
Eksik Adımlar
This is a replacement guide for the DJI Mini 2's propeller blades.
The propellers are on the DJI Mini 2 help the drone generate lift for the drone when it is flying. A drone propeller will need to be replaced if the propeller is damaged and causes the drone to hover in an inconsistent way.
Neye ihtiyacın var
  1. DJI Mini 2 Propeller Blades Replacement, Propeller Blades: adım 1, 1 resimden 1.
    • Open up the propeller arms to make it easier to access the propeller blades.
    • Then, place the drone on a flat surface.
    • There should be stickers on the device telling you how to unfold the propeller arms.
  2. DJI Mini 2 Propeller Blades Replacement: adım 2, 2 resimden 1. DJI Mini 2 Propeller Blades Replacement: adım 2, 2 resimden 2.
    • Remove the 7mm J000 head screw attaching the blade to the motor.
    • Some pressure may be needed to successfully unscrew the screw.
    • Remove the propeller blades.
Sonuç
Jacob Matos
1.167 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team F-1, Gurgel Spring 2022 UMass Dartmouth, Team F-1, Gurgel Spring 2022 üyesi
UMASSD-GURGEL-S22SFG1
2 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 16
Son 30 gün: 23
Her zaman: 2,034
