Giriş
Hi everyone, In this guide, I'll show you how to replace the gimbal assembly or gimbal housing on the DJI Mini 3 Pro drone.
After replacing the gimbal camera, you may need to calibrate your drone, but this cannot be done using the DJI Fly mobile app, you will need to use additional software. How to calibrate the gimbal watch this video tutorial https://youtu.be/mu03HWXplM4
Neye ihtiyacın var
Video talimatları
To reassemble your device, follow these instructions.
6 farklı kişi bu kılavuzu tamamladı.
12 Yorum
Does anyone have a source for replacing the little rubber gimbal mounts?
Andre Purdy - Yanıt
HI there! Does anyone know where I can buy the whole gimbal in USA? I remember seeing it somewhere but cannot find it
gbonilla - Yanıt
Go to YouTube and check the link to the gimbal assembly in the description below the video
Arty -
mini 3 pro com port not show on device manegar any help.
Limon Khan - Yanıt
Bonjour, le port COM ne s'affiche pas sur mon pc, comment faire ?
Sébastien Perroux -
Start trembling during flight after a horizontal stop. At the start, I can hear the gimbal noise from trembling (before taking off). I gently touch it, and it stops. I take off and fly a long distance.
If I stop it or it stops it by signal loss, the trembling starts again. if I never stop it and take gentle curves back, it may work. At abrupt stops, it starts trembling. I bring the drone back to me at 1-meter height. I gently touch the gimbal (without landing), and it stops. Then I fly again (if the battery is low, I land, change the battery, and start again, same steps, every time). I will probably buy a new one, so I can send this to repairs - did not check the guarantee yet.
- no problems during climbing up.
- only on horizontal movements and hard stops (release the lever on the controller).
I will try never to release the lever abruptly and never lose signal (a signal lost could be a hard brake, also)
??? Calibration can stop this strange error ????
Dorin - Yanıt
Check the metal piece of the gimbal to make sure it is not broken anywhere. That can cause the camera to vibrate.
Frankie Snaps -
bonjour,
ou peut on trouver la piece neuve ?
Cédric Rovelli - Yanıt
Hey what parts do I need to get and where to get them from in au. I crashed and it’s broken the right side of the gimbal completely off. The camera still looks fine and working but there is a cable snapped off. any help would be much appreciated
Brody D - Yanıt
I don't know how to get the parts in AU, but I just had the same problem and fixed it. If the motors still rotate, then it shouldn't be too hard (or expensive) to fix. I just replaced the cable, the plastic covering and the rubber dampeners, and it worked. This was the video that was really helpful.
https://youtu.be/fiebNX5f1r8?feature=sha...
MJT -
There was no link to order the Gimbal replacement part???
citsalllc - Yanıt
Hey - I recently knocked my Mini 3 Pro into a wall, there was a slight crack to the body but nothing bad HOWEVER the cable feeding into the camera/gimbal is exposed as the plastic part originally there (only a little circular ish piece on the back of the camera) came off. Any idea what that is called and where I can get it? Thanks
AdamD - Yanıt
