Ana içeriğe geç
DJI Phantom 3 Advanced Cover Replacement
Robert Comstock
Robert Comstock ve 3 diğer katkıda bulunanlar
En son March 31, 2020 tarihinde güncellendi
10 dakika
Orta
This guide will illustrate the needed steps in removing the plastic shell from the DJI Phantom 3 Advanced. This includes the removal of screws that secure the two halves of the shell together. This guide also informs how to safely remove the top shell after it is unscrewed. This is a process required for removing several other components.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. DJI Phantom 3 Advanced Cover Replacement, Battery: adım 1, 2 resimden 1. DJI Phantom 3 Advanced Cover Replacement, Battery: adım 1, 2 resimden 2.
    • With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
    • Remember to disarm and power down your quadcopter before beginning any disassembly.
  2. DJI Phantom 3 Advanced Cover Replacement: adım 2, 2 resimden 1. DJI Phantom 3 Advanced Cover Replacement: adım 2, 2 resimden 2.
    • Press the two tabs with your finger and thumb, and gently slide the battery towards you, out of the quadcopter frame.
    • With your other hand, be sure to hold the quadcopter steady to ensure that it stays still.
  3. DJI Phantom 3 Advanced Cover Replacement, Cover: adım 3, 1 resimden 1.
    • Turn the Phantom 3 Advanced upside down.
  4. DJI Phantom 3 Advanced Cover Replacement: adım 4, 1 resimden 1.
    • Remove the four 7mm long 2mm screws with a T-6 screwdriver.
    • There is one screw per arm, located at the tip of the arm.
  5. DJI Phantom 3 Advanced Cover Replacement: adım 5, 2 resimden 1. DJI Phantom 3 Advanced Cover Replacement: adım 5, 2 resimden 2.
    • Remove the eight 5mm long 2.5mm screws using the T-8 screwdriver.
    • There are two 5mm screws on each arm.
  6. DJI Phantom 3 Advanced Cover Replacement: adım 6, 2 resimden 1. DJI Phantom 3 Advanced Cover Replacement: adım 6, 2 resimden 2.
    • Remove the four 10mm long deep 3mm screws using the T-8 screwdriver.
    • There is one screw on each arm located near the landing gear.
  7. DJI Phantom 3 Advanced Cover Replacement: adım 7, 3 resimden 1. DJI Phantom 3 Advanced Cover Replacement: adım 7, 3 resimden 2. DJI Phantom 3 Advanced Cover Replacement: adım 7, 3 resimden 3.
    • Carefully flip the phantom back over with the motors facing up.
    • Peel back the silver stickers from the seam in the cover.
    • Using a plastic spudger, slowly separate the two halves of the plastic shell.
    • This step requires some force, and the plastic will click loudly as the shell separates.
    • Do not fully remove the cover. There is a wire that needs to be detached from the control board before the cover is completely free.
  8. DJI Phantom 3 Advanced Cover Replacement: adım 8, 3 resimden 1. DJI Phantom 3 Advanced Cover Replacement: adım 8, 3 resimden 2. DJI Phantom 3 Advanced Cover Replacement: adım 8, 3 resimden 3.
    • Slowly remove the upper half of the plastic case about halfway. There is a ribbon cable that's connects the cover and the control board.
    • Follow the ribbon cable to the control board and locate the connector that connects the cable to the control board.
    • Press the tab on the side of the connector and pull up on the cable.
    • Continue to remove the shell the rest of the way.
    “Press the tab on the side of the connector and pull up on the cable.”
    The 2015 W323A model I am working on has no tab on the side of the connector. Connector released quite easily when I applied upward pressure away from the board, pulling on the all wires together. A little wiggle side to side helped. Be patient. It’s a small connector.
    O Smith - Yanıt
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Robert Comstock
433 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-2, Livingston Fall 2016 Cal Poly, Team 10-2, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S10G2
3 Üyeler
12 adet Kılavuz yazıldı
3 Yorum
Great Job Robert! Even the “Phantom Pilots Forum” had no recent recommendations for a disassembly manual, as DJI likes to “Fixit” themselves!
Michael Steinbrecher - Yanıt
Excellent detailed instructions. Having pictures on procedure makes it idiot proof.
Bolo - Yanıt
Does this also include the phantom 3 professional too? My understanding is that the only differences between them is the battery charger and the pro is 4k recording vs 1080p.
John D - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 5,034
