Ana içeriğe geç
DJI Phantom 3 Advanced Flight Controller Replacement
Neye ihtiyacın var
    1. DJI Phantom 3 Advanced Flight Controller Replacement, Battery: adım 1, 2 resimden 1. DJI Phantom 3 Advanced Flight Controller Replacement, Battery: adım 1, 2 resimden 2.
      • With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
      • Remember to disarm and power down your quadcopter before beginning any disassembly.
      FixBot'a Sor
      Yorum Ekle
    2. DJI Phantom 3 Advanced Flight Controller Replacement: adım 2, 2 resimden 1. DJI Phantom 3 Advanced Flight Controller Replacement: adım 2, 2 resimden 2.
      • Press the two tabs with your finger and thumb, and gently slide the battery towards you, out of the quadcopter frame.
      • With your other hand, be sure to hold the quadcopter steady to ensure that it stays still.
      FixBot'a Sor
      Yorum Ekle
    1. DJI Phantom 3 Advanced Flight Controller Replacement, Cover: adım 3, 1 resimden 1.
      • Turn the Phantom 3 Advanced upside down.
      FixBot'a Sor
      Yorum Ekle
    2. DJI Phantom 3 Advanced Flight Controller Replacement: adım 4, 1 resimden 1.
      • Remove the four 7mm long 2mm screws with a T-6 screwdriver.
      • There is one screw per arm, located at the tip of the arm.
      FixBot'a Sor
      Yorum Ekle
    3. DJI Phantom 3 Advanced Flight Controller Replacement: adım 5, 2 resimden 1. DJI Phantom 3 Advanced Flight Controller Replacement: adım 5, 2 resimden 2.
      • Remove the eight 5mm long 2.5mm screws using the T-8 screwdriver.
      • There are two 5mm screws on each arm.
      FixBot'a Sor
      Yorum Ekle
    4. DJI Phantom 3 Advanced Flight Controller Replacement: adım 6, 2 resimden 1. DJI Phantom 3 Advanced Flight Controller Replacement: adım 6, 2 resimden 2.
      • Remove the four 10mm long deep 3mm screws using the T-8 screwdriver.
      • There is one screw on each arm located near the landing gear.
      FixBot'a Sor
      Yorum Ekle
    5. DJI Phantom 3 Advanced Flight Controller Replacement: adım 7, 3 resimden 1. DJI Phantom 3 Advanced Flight Controller Replacement: adım 7, 3 resimden 2. DJI Phantom 3 Advanced Flight Controller Replacement: adım 7, 3 resimden 3.
      • Carefully flip the phantom back over with the motors facing up.
      • Peel back the silver stickers from the seam in the cover.
      • Using a plastic spudger, slowly separate the two halves of the plastic shell.
      • This step requires some force, and the plastic will click loudly as the shell separates.
      • Do not fully remove the cover. There is a wire that needs to be detached from the control board before the cover is completely free.
      FixBot'a Sor
      Yorum Ekle
    6. DJI Phantom 3 Advanced Flight Controller Replacement: adım 8, 3 resimden 1. DJI Phantom 3 Advanced Flight Controller Replacement: adım 8, 3 resimden 2. DJI Phantom 3 Advanced Flight Controller Replacement: adım 8, 3 resimden 3.
      • Slowly remove the upper half of the plastic case about halfway. There is a ribbon cable that's connects the cover and the control board.
      • Follow the ribbon cable to the control board and locate the connector that connects the cable to the control board.
      • Press the tab on the side of the connector and pull up on the cable.
      • Continue to remove the shell the rest of the way.
      FixBot'a Sor
      Yorum Ekle
    1. DJI Phantom 3 Advanced Flight Controller Replacement, Flight Controller: adım 9, 1 resimden 1.
      • Locate the five ribbon cables that need to be disconnected from the control board.
      • Locate the red and black battery wires.
      • Follow the three wires from each motor and the three wires from each LED to where they connect on the control board.
      FixBot'a Sor
      Yorum Ekle
    2. DJI Phantom 3 Advanced Flight Controller Replacement: adım 10, 3 resimden 1. DJI Phantom 3 Advanced Flight Controller Replacement: adım 10, 3 resimden 2. DJI Phantom 3 Advanced Flight Controller Replacement: adım 10, 3 resimden 3.
      • Use a plastic opening tool to remove the glue that covers the motor and LED wires. Use a metal opening tool if necessary.
      • Desolder the six motor and LED wires where they connect on the flight controller for each arm. Refer to the Desoldering Guide on how to desolder.
      • Desolder the battery wires.
      FixBot'a Sor
      Yorum Ekle
    3. DJI Phantom 3 Advanced Flight Controller Replacement: adım 11, 2 resimden 1. DJI Phantom 3 Advanced Flight Controller Replacement: adım 11, 2 resimden 2.
      • Remove the cable next to where the battery wires were connected. Pinch and hold the top of the connector, then pull it out.
      FixBot'a Sor
      Yorum Ekle
    4. DJI Phantom 3 Advanced Flight Controller Replacement: adım 12, 3 resimden 1. DJI Phantom 3 Advanced Flight Controller Replacement: adım 12, 3 resimden 2. DJI Phantom 3 Advanced Flight Controller Replacement: adım 12, 3 resimden 3.
      • Remove the black ribbon cable and the 3-wire cable next to it. Press the small tab on the ribbon cable connector and pull it out.
      FixBot'a Sor
      Yorum Ekle
    5. DJI Phantom 3 Advanced Flight Controller Replacement: adım 13, 3 resimden 1. DJI Phantom 3 Advanced Flight Controller Replacement: adım 13, 3 resimden 2. DJI Phantom 3 Advanced Flight Controller Replacement: adım 13, 3 resimden 3.
      • Locate the ribbon cable that is next to the word "Front" on the flight controller.
      • Remove the small cable next to the ribbon cable by pinching on the side tab and pulling up on the connector. It has black, red and yellow wires.
      • Remove the black band from the ribbon cable.
      • Remove the ribbon cable by pinching on the side tab and pulling up on the connector.
      FixBot'a Sor
      Yorum Ekle
    6. DJI Phantom 3 Advanced Flight Controller Replacement: adım 14, 2 resimden 1. DJI Phantom 3 Advanced Flight Controller Replacement: adım 14, 2 resimden 2.
      • Remove the four 6.5mm long 2mm screws with a philips head 00 screwdriver.
      • Remove the flight controller now by slowly pulling if off of the frame.
      FixBot'a Sor
      Yorum Ekle
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Robert Comstock
436 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-2, Livingston Fall 2016 Cal Poly, Team 10-2, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S10G2
3 Üyeler
36 adet Kılavuz yazıldı
2Kılavuz Yorumları
Very clear and helpful. Thank You.
Herb - Yanıt Paylaş
Excellent with great visuals. Can really see what to do
Leo Miller - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 54
Her zaman: 8,165
