Ana içeriğe geç
DJI Phantom 3 Advanced Landing Gear Replacement
Neye ihtiyacın var
  1. DJI Phantom 3 Advanced Landing Gear Replacement, Battery: adım 1, 2 resimden 1. DJI Phantom 3 Advanced Landing Gear Replacement, Battery: adım 1, 2 resimden 2.
    • With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
    • Remember to disarm and power down your quadcopter before beginning any disassembly.
  2. DJI Phantom 3 Advanced Landing Gear Replacement: adım 2, 2 resimden 1. DJI Phantom 3 Advanced Landing Gear Replacement: adım 2, 2 resimden 2.
    • Press the two tabs with your finger and thumb, and gently slide the battery towards you, out of the quadcopter frame.
    • With your other hand, be sure to hold the quadcopter steady to ensure that it stays still.
  3. DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: adım 3, 3 resimden 1. DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: adım 3, 3 resimden 2. DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: adım 3, 3 resimden 3.
    • Turn the phantom upside down.
    • Remove the eight 7.5mm long 3mm screws, securing the landing gear to the body of the quadcopter, with a T-8 screwdriver.
  4. DJI Phantom 3 Advanced Landing Gear Replacement: adım 4, 3 resimden 1. DJI Phantom 3 Advanced Landing Gear Replacement: adım 4, 3 resimden 2. DJI Phantom 3 Advanced Landing Gear Replacement: adım 4, 3 resimden 3.
    • Remove the rubber spacer in the landing gear by pushing the spacer out of the slot with your finger.
  5. DJI Phantom 3 Advanced Landing Gear Replacement: adım 5, 3 resimden 1. DJI Phantom 3 Advanced Landing Gear Replacement: adım 5, 3 resimden 2. DJI Phantom 3 Advanced Landing Gear Replacement: adım 5, 3 resimden 3.
    • Using a plastic opening tool, carefully separate the two pieces of plastic of the landing gear.
    • Be careful not to break the wire attached, as this is your receiver antenna.
  6. DJI Phantom 3 Advanced Landing Gear Replacement: adım 6, 3 resimden 1. DJI Phantom 3 Advanced Landing Gear Replacement: adım 6, 3 resimden 2. DJI Phantom 3 Advanced Landing Gear Replacement: adım 6, 3 resimden 3.
    • Feed the wire and attached plastic through the hole in the landing gear.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Quinn Tirpak
325 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-2, Livingston Fall 2016 Cal Poly, Team 10-2, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S10G2
3 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
I have a single coax cable in my landing gear. the gear broke and the wire tore off the connector. How do I fix this?
Art - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 22
Her zaman: 3,920
