Ana içeriğe geç
DJI Phantom 3 Standard Remote Controller Antenna Replacement
Makayla Williams
Makayla Williams ve 3 diğer katkıda bulunanlar
En son January 3, 2025 tarihinde güncellendi
5 - 10 dakika
Kolay
This guide will be used to open the DJI Phantom 3 Standard Remote Controller to access and replace the antenna. Antennas are a crucial controller component because they allow for communication between the controller and the drone. An antenna replacement can improve the connection between your controller and the drone. Some antennas provide a larger controller range compared to the stock antenna.
Neye ihtiyacın var
Aletler
  1. DJI Phantom 3 Standard Remote Controller Antenna Replacement, Antenna: adım 1, 2 resimden 1. DJI Phantom 3 Standard Remote Controller Antenna Replacement, Antenna: adım 1, 2 resimden 2.
    • Position the controller so the back is facing up and the joysticks are resting on the table.
    • Remove the four 11 mm screws that secure the back plate using a JIS #0 screwdriver.
    • Remove the back plate, being mindful of the wires still connected to the device.
  2. DJI Phantom 3 Standard Remote Controller Antenna Replacement: adım 2, 2 resimden 1. DJI Phantom 3 Standard Remote Controller Antenna Replacement: adım 2, 2 resimden 2.
    • Use a spudger to pry the gray antenna wire from the glue.
    • There is a small metal piece latched in and should be removed from its place as well.
    • While a plastic spudger can be used, the attachment is secure. A metal spudger may produce better results.
  3. DJI Phantom 3 Standard Remote Controller Antenna Replacement: adım 3, 1 resimden 1.
    • Push the wire up to the antenna.
  4. DJI Phantom 3 Standard Remote Controller Antenna Replacement: adım 4, 1 resimden 1.
    • Squeeze and twist the outer antenna attachment to unlatch it from its place.
    • Remove the antenna.
Sonuç
Makayla Williams
209 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 26
Son 30 gün: 48
Her zaman: 94
