Ana içeriğe geç
DJI Phantom 3 Standard Remote Controller Joysticks Replacement
Neye ihtiyacın var
  1. DJI Phantom 3 Standard Remote Controller Joysticks Replacement, Joysticks: adım 1, 2 resimden 1. DJI Phantom 3 Standard Remote Controller Joysticks Replacement, Joysticks: adım 1, 2 resimden 2.
    • Position the controller so the back is facing up and the joysticks are resting on the table.
    • Remove the four 11 mm screws that secure the back plate using a JIS #0 screwdriver.
    • Remove the back plate, being mindful of the wires still connected to the device.
  2. DJI Phantom 3 Standard Remote Controller Joysticks Replacement: adım 2, 1 resimden 1.
    • On the inside of the controller, remove the four 11 mm screws that cover the base housing of the joystick.
  3. DJI Phantom 3 Standard Remote Controller Joysticks Replacement: adım 3, 3 resimden 1. DJI Phantom 3 Standard Remote Controller Joysticks Replacement: adım 3, 3 resimden 2. DJI Phantom 3 Standard Remote Controller Joysticks Replacement: adım 3, 3 resimden 3.
    • Inside the base housing, remove the two 9 mm screws that secure the joystick brace piece on both the left and right side of the stick.
    • Remove the braces on the left and right sides of the joystick to reach the circuit board piece on the left.
    • Detach the circuit board piece.
  4. DJI Phantom 3 Standard Remote Controller Joysticks Replacement: adım 4, 2 resimden 1. DJI Phantom 3 Standard Remote Controller Joysticks Replacement: adım 4, 2 resimden 2.
    • Separate the other circuit board piece from the joystick connection using a plastic spudger.
    • The circuit board is wired through glue. If the plastic spudger is unable to pry the glue off, use the metal spudger as a last resort.
    • Take the joystick module itself and remove the four 8 mm screws that connect the joystick to the housing.
    • Unscrew the thumb stick from the module if a replacement is not needed.
  5. DJI Phantom 3 Standard Remote Controller Joysticks Replacement: adım 5, 1 resimden 1.
    • Remove the joystick.
Sonuç
Maddie McCoy
229 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 26
Her zaman: 65
