Ana içeriğe geç
DJI Phantom 4 Advanced Remote Controller Motherboard Replacement
cade knott
cade knott ve 6 diğer katkıda bulunanlar
En son August 12, 2021 tarihinde güncellendi
10 - 15 dakika
Zor
İşlem Görüntüleri
This guide will show you how to remove and replace the motherboard of the DJI Phantom 4 Advanced Remote Controller.
Before you begin:
  • Please make sure to completely power off the the controller prior to any replacements.
  • Please read the guide before any replacements in order to familiarize yourself with the process.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: adım 2, 2 resimden 1. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove three screws using a Phillips #00 screwdriver.
  3. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: adım 3, 2 resimden 1. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: adım 4, 2 resimden 1. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: adım 4, 2 resimden 2.
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  5. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: adım 5, 2 resimden 1. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: adım 5, 2 resimden 2.
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
  6. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement, Motherboard: adım 6, 3 resimden 1. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement, Motherboard: adım 6, 3 resimden 2. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement, Motherboard: adım 6, 3 resimden 3.
    • Disconnect ribbon tabs 1,2,5,8G, and 3.
    • Remove ribbon tab by pulling gently along motherboard. Do not pull straight out.
    • Then remove the plugs
  7. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: adım 7, 2 resimden 1. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: adım 7, 2 resimden 2.
    • With the Phillips #00 screwdriver, remove the two Phillips screws.
  8. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: adım 8, 1 resimden 1.
    • Double check to make sure all tabs, plugs and screws are removed or disconnected.
    • Gently lift motherboard out of the case.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Do you know here can i buy a main board for phantom 4 advanced remote controller?
carl_darklife - Yanıt
I would like to know too, can’t find one anywhere
Luke James -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 2,195
