Ana içeriğe geç
DJI Spark Camera Replacement
Neye ihtiyacın var
  1. DJI Spark Camera Replacement, Propellers: adım 1, 1 resimden 1.
    • Push down on the propeller that is being replaced.
    Just a warning, I just tried this guide and it is missing tons of steps, so be careful when you try yourself.
    MisterGuy’s Channel - Yanıt
  2. DJI Spark Camera Replacement: adım 2, 2 resimden 1. DJI Spark Camera Replacement: adım 2, 2 resimden 2.
    • Twist the propeller until it feels loose.
    • Pull on it until it comes off.
  3. DJI Spark Camera Replacement, Battery: adım 3, 3 resimden 1. DJI Spark Camera Replacement, Battery: adım 3, 3 resimden 2. DJI Spark Camera Replacement, Battery: adım 3, 3 resimden 3.
    • Flip the drone over.
    • Grip the left and right sides of the battery.
    • Slide firmly forward until it pops out.
  4. DJI Spark Camera Replacement, Lid: adım 4, 3 resimden 1. DJI Spark Camera Replacement, Lid: adım 4, 3 resimden 2. DJI Spark Camera Replacement, Lid: adım 4, 3 resimden 3.
    • Remove the four 1.5mm Hex screws.
    • Remove the two 1.5mm Hex screws near the camera head.
    • You may need to remove plastic nubs from the hex screws using a spudger first.
    The middle two screws appear to have their hex holes plugged with clear plastic.
    Basil Yokarinis - Yanıt
    How do you remove it?
    MontesDesigns -
  5. DJI Spark Camera Replacement: adım 5, 3 resimden 1. DJI Spark Camera Replacement: adım 5, 3 resimden 2. DJI Spark Camera Replacement: adım 5, 3 resimden 3.
    • Hold the drone so the lid is facing up.
    • Insert the plastic opening tool into the side of the drone.
    • Slide the tool around the perimeter until you can lift the top off.
  6. DJI Spark Camera Replacement, Camera: adım 6, 2 resimden 1. DJI Spark Camera Replacement, Camera: adım 6, 2 resimden 2.
    • Disconnect two gold antenna next to the internal GPS while removing the motherboard.
  7. DJI Spark Camera Replacement: adım 7, 3 resimden 1. DJI Spark Camera Replacement: adım 7, 3 resimden 2. DJI Spark Camera Replacement: adım 7, 3 resimden 3.
    • Remove all the Phillips #0 screws attaching the motherboard to the drone.
    • It is the piece with both the fan and GPS module on it.
    One screw circle is off by a bit
  8. DJI Spark Camera Replacement: adım 8, 2 resimden 1. DJI Spark Camera Replacement: adım 8, 2 resimden 2.
    • Remove the 3.0 mm Phillips #000 screw.
    There is no steps for removing the logic board. Just find the flex cables under the foam and remove them, then you can move the logic board out. Hope this helps!
  9. DJI Spark Camera Replacement: adım 9, 3 resimden 1. DJI Spark Camera Replacement: adım 9, 3 resimden 2. DJI Spark Camera Replacement: adım 9, 3 resimden 3.
    • Remove the two Phillips #0 screws on the right and left sides.
    • Once removed, pull the front facing sensor out.
  10. DJI Spark Camera Replacement: adım 10, 3 resimden 1. DJI Spark Camera Replacement: adım 10, 3 resimden 2. DJI Spark Camera Replacement: adım 10, 3 resimden 3.
    • Gently remove the gimbal along with the camera from the top of the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Amelia Hagberg
445 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G7, Botvin Fall 2019 UMass Dartmouth, Team S1-G7, Botvin Fall 2019 üyesi
UMASSD-BOTVIN-F19S1G7
3 Üyeler
7 adet Kılavuz yazıldı
2 Yorum
Good start, but missing many steps and details.
I am now going to try and fix my drone. thank you so much
sebasnavarro1116 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 77
Her zaman: 6,323
