Ana içeriğe geç
DOPO 10.1 Tablet Battery Replacement
Neye ihtiyacın var
  1. DOPO 10.1 Tablet Battery Replacement, Remove Back: adım 1, 3 resimden 1. DOPO 10.1 Tablet Battery Replacement, Remove Back: adım 1, 3 resimden 2. DOPO 10.1 Tablet Battery Replacement, Remove Back: adım 1, 3 resimden 3.
    • Take plastic opening tools, and find a spot on the back of tablet to lift the back plate. Once back is lifted enough, remove the back of the tablet carefully with fingers
  2. DOPO 10.1 Tablet Battery Replacement, Locate Battery: adım 2, 1 resimden 1.
    • Locate battery, and examine wires connected to battery.
  3. DOPO 10.1 Tablet Battery Replacement, Remove Battery: adım 3, 3 resimden 1. DOPO 10.1 Tablet Battery Replacement, Remove Battery: adım 3, 3 resimden 2. DOPO 10.1 Tablet Battery Replacement, Remove Battery: adım 3, 3 resimden 3.
    • Carefully remove battery without putting any strain on connected wires. The battery is held to the tablet with adhesive, so be careful not to jerk the battery when it becomes loose.
  4. DOPO 10.1 Tablet Battery Replacement, Disconnect Wires: adım 4, 3 resimden 1. DOPO 10.1 Tablet Battery Replacement, Disconnect Wires: adım 4, 3 resimden 2. DOPO 10.1 Tablet Battery Replacement, Disconnect Wires: adım 4, 3 resimden 3.
    • Use a soldering iron to carefully remove wires from motherboard. Then remove battery.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kaitlyn Hayes
414 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-2, Brown Winter 2015 USF Tampa, Team 5-2, Brown Winter 2015 üyesi
USFT-BROWN-W15S5G2
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 19
Her zaman: 2,495
