Ana içeriğe geç
DOSS SoundBox Base-plate Replacement
Neye ihtiyacın var
  1. DOSS SoundBox Base-plate Replacement, Base-plate: adım 1, 3 resimden 1. DOSS SoundBox Base-plate Replacement, Base-plate: adım 1, 3 resimden 2. DOSS SoundBox Base-plate Replacement, Base-plate: adım 1, 3 resimden 3.
    • Locate the four 3/32" screws on the bottom of your device.
    • Using a JIS #00 screwdriver, remove the four 3/32" screws.
    • After removing the screws, lift the cover off of the device.
  2. DOSS SoundBox Base-plate Replacement: adım 2, 1 resimden 1.
    • Using a JIS #1 screwdriver, remove the six 3/32" screws that attach the base-plate to the speaker enclosure. These screws are marked with red circles.
    • Using a JIS #000 screwdriver, remove the two 1/16" screws from the areas marked with an orange circle.
    • Having the magnetic pad handy will be beneficial, as these screws are very small and easily lost.
  3. DOSS SoundBox Base-plate Replacement: adım 3, 1 resimden 1.
    • Lift the base-plate off of the enclosure.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Speaker had an unusual sound. Followed guide, really easy to work on. Diagnosis broken speaker membrane.
Albi No - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 43
Her zaman: 2,160
