Ana içeriğe geç
DOSS SoundBox Base-plate Replacement
Brendan Harkreader
Brendan Harkreader ve 4 diğer katkıda bulunanlar
En son January 10, 2025 tarihinde güncellendi
5 - 15 dakika
Kolay
This guide will help you replace or remove the base plate on your DOSS SoundBox portable Bluetooth speaker, which provides structural integrity and protects the device's internal components. The base plate may need replacement if your speaker shows signs of physical instability or sound distortion coming from the base of the speaker. Before starting, ensure the device is powered off to avoid accidental damage.
Neye ihtiyacın var
  1. DOSS SoundBox Base-plate Replacement, Base-plate: adım 1, 3 resimden 1. DOSS SoundBox Base-plate Replacement, Base-plate: adım 1, 3 resimden 2. DOSS SoundBox Base-plate Replacement, Base-plate: adım 1, 3 resimden 3.
    • Locate the four 3/32" screws on the bottom of your device.
    • Using a JIS #00 screwdriver, remove the four 3/32" screws.
    • After removing the screws, lift the cover off of the device.
  2. DOSS SoundBox Base-plate Replacement: adım 2, 1 resimden 1.
    • Using a JIS #1 screwdriver, remove the six 3/32" screws that attach the base-plate to the speaker enclosure. These screws are marked with red circles.
    • Using a JIS #000 screwdriver, remove the two 1/16" screws from the areas marked with an orange circle.
    • Having the magnetic pad handy will be beneficial, as these screws are very small and easily lost.
  3. DOSS SoundBox Base-plate Replacement: adım 3, 1 resimden 1.
    • Lift the base-plate off of the enclosure.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Speaker had an unusual sound. Followed guide, really easy to work on. Diagnosis broken speaker membrane.
Albi No - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 43
Her zaman: 2,157
