Ana içeriğe geç
DROCON Ninja Camera Replacement
Neye ihtiyacın var
  1. DROCON Ninja Camera Replacement, Battery: adım 1, 3 resimden 1. DROCON Ninja Camera Replacement, Battery: adım 1, 3 resimden 2. DROCON Ninja Camera Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure the drone is powered off before beginning the battery replacement.
    • To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
    • Firmly grasp the battery tab between your thumb and index finger.
    • Pull the battery away from the drone's body
    FixBot'a Sor
    Yorum Ekle
  2. DROCON Ninja Camera Replacement, Casing: adım 2, 3 resimden 1. DROCON Ninja Camera Replacement, Casing: adım 2, 3 resimden 2. DROCON Ninja Camera Replacement, Casing: adım 2, 3 resimden 3.
    • Using a Phillips #00 Screwdriver remove the eight 4mm screws on the bottom of the drone.
    FixBot'a Sor
    Yorum Ekle
  3. DROCON Ninja Camera Replacement: adım 3, 2 resimden 1. DROCON Ninja Camera Replacement: adım 3, 2 resimden 2.
    • Gently pull white casing away from the black bottom casing
    FixBot'a Sor
    Yorum Ekle
  4. DROCON Ninja Camera Replacement: adım 4, 3 resimden 1. DROCON Ninja Camera Replacement: adım 4, 3 resimden 2. DROCON Ninja Camera Replacement: adım 4, 3 resimden 3.
    • Insert the opening tool under one of the black plastic connector slots that connects the circuit-board to the casing.
    • Gently pull the opening tool toward you to disconnect the circuit-board from the plastic casing.
    FixBot'a Sor
    Yorum Ekle
  5. DROCON Ninja Camera Replacement, Camera: adım 5, 3 resimden 1. DROCON Ninja Camera Replacement, Camera: adım 5, 3 resimden 2. DROCON Ninja Camera Replacement, Camera: adım 5, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the 5mm screws connecting the front two motor arms to the drone's body.
    • Use your fingers to gently pull the white plastic discs out of the motor arms.
    FixBot'a Sor
    Yorum Ekle
  6. DROCON Ninja Camera Replacement: adım 6, 2 resimden 1. DROCON Ninja Camera Replacement: adım 6, 2 resimden 2.
    • Grasp the motor arm and pull up and away from the drone's body.
    • Repeat this step for the other front motor arm.
    FixBot'a Sor
    Yorum Ekle
  7. DROCON Ninja Camera Replacement: adım 7, 3 resimden 1. DROCON Ninja Camera Replacement: adım 7, 3 resimden 2. DROCON Ninja Camera Replacement: adım 7, 3 resimden 3.
    • Using the Phillips #00 screwdriver, remove the two 3mm screws on the control board.
    FixBot'a Sor
    Yorum Ekle
  8. DROCON Ninja Camera Replacement: adım 8, 3 resimden 1. DROCON Ninja Camera Replacement: adım 8, 3 resimden 2. DROCON Ninja Camera Replacement: adım 8, 3 resimden 3.
    • Using the opening tool flip up the black plastic clamp that holds the camera wire to the circuit board.
    • Gently pull the camera out from the control board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 574
