Ana içeriğe geç
Dashcam DOD LS300W Battery Replacement
Neye ihtiyacın var
  1. Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: adım 1, 3 resimden 1. Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: adım 1, 3 resimden 2. Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: adım 1, 3 resimden 3.
    • Using an opening tool, pry open the seam on the bottom of the dash cam to separate the two parts of the device.
  2. Dashcam DOD LS300W Battery Replacement: adım 2, 2 resimden 1. Dashcam DOD LS300W Battery Replacement: adım 2, 2 resimden 2.
    • Notice the connection of + and - on the top left side of the inside of the dash cam. Make note of this as it will be important to remember when you solder on the new battery.
    • Desolder the old battery. This is a 250mAh.
  3. Dashcam DOD LS300W Battery Replacement: adım 3, 3 resimden 1. Dashcam DOD LS300W Battery Replacement: adım 3, 3 resimden 2. Dashcam DOD LS300W Battery Replacement: adım 3, 3 resimden 3.
    • The new battery is 400mAh. and fits just in the battery location.
    • Solder in the new battery.
    • Then place the new battery into the space previously occupied by the old battery.
    • See the difference between old and new battery.
    • Be careful to solder the positive side of the new battery into the same spot that the old battery was soldered into.
  4. Dashcam DOD LS300W Battery Replacement: adım 4, 1 resimden 1.
    • Put the dashcam back together.
    • Charge the battery to the full level, and you are ready to go.
Sonuç
Once again, thank you for checking out this guide and I hope it helped!
2 farklı kişi bu kılavuzu tamamladı.
Pierre
542 İtibar
3 adet Kılavuz yazıldı
2 Yorum
Hi mate, where did you buy the replacement battery from? I'm having trouble finding something online? blackdogwood@bigpond.com
Cheers,
Russell Edwards - Yanıt
Hi Russell, I found this battery on Ebay.
Good luck.
Cheers.
Pierre - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 40
Her zaman: 6,377
