Ana içeriğe geç
DeWALT DW106 Amp Drill Maintenance
Joanna
Joanna ve 2 diğer katkıda bulunanlar
En son July 18, 2014 tarihinde güncellendi
20 dakika
Kolay
Topluluk-Katkılı Kılavuz
Use this guide to disassemble your drill for cleaning, troubleshooting, or other maintenance.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. DeWALT DW106 Amp Drill Maintenance, Drill: adım 1, 2 resimden 1. DeWALT DW106 Amp Drill Maintenance, Drill: adım 1, 2 resimden 2.
    • Remove the seven T20 screws.
    • Use the T-handle configuration of the screwdriver for the necessary force to loosen the screws.
    • This drill required some cleaning to access the heads of the screws.
  2. DeWALT DW106 Amp Drill Maintenance: adım 2, 2 resimden 1. DeWALT DW106 Amp Drill Maintenance: adım 2, 2 resimden 2.
    • Wiggle the power supply cord to loosen the clamshell set and rotate the case open.
    • Remove the bubble level.
  3. DeWALT DW106 Amp Drill Maintenance: adım 3, 2 resimden 1. DeWALT DW106 Amp Drill Maintenance: adım 3, 2 resimden 2.
    • Disengage and remove the spindle and gear assembly.
    • Lift out the field assembly and armature.
  4. DeWALT DW106 Amp Drill Maintenance: adım 4, 3 resimden 1. DeWALT DW106 Amp Drill Maintenance: adım 4, 3 resimden 2. DeWALT DW106 Amp Drill Maintenance: adım 4, 3 resimden 3.
    • Slide the armature out of the field assembly.
    • Rotate the field assembly to lay on the top. This allows for easier access to the frayed wire.
  5. DeWALT DW106 Amp Drill Maintenance: adım 5, 3 resimden 1. DeWALT DW106 Amp Drill Maintenance: adım 5, 3 resimden 2. DeWALT DW106 Amp Drill Maintenance: adım 5, 3 resimden 3.
    • Cut a piece of electrical tape about one inch long.
    • Wrap it tightly around the frayed section of the wiring.
    • It is easier to start with one of the corners and wrap the tape at an angle.
  6. DeWALT DW106 Amp Drill Maintenance: adım 6, 2 resimden 1. DeWALT DW106 Amp Drill Maintenance: adım 6, 2 resimden 2.
    • Lay the field assembly back down and align the armature.
    • Reinsert the armature and rotate to point it "drill downward."
  7. DeWALT DW106 Amp Drill Maintenance: adım 7, 3 resimden 1. DeWALT DW106 Amp Drill Maintenance: adım 7, 3 resimden 2. DeWALT DW106 Amp Drill Maintenance: adım 7, 3 resimden 3.
    • Compress the brushes in the brush ring so the ball bearing at the end of the armature assembly can get through.
    • Use a spudger or similar thin tool.
    • Side view. This is not far enough.
  8. DeWALT DW106 Amp Drill Maintenance: adım 8, 2 resimden 1. DeWALT DW106 Amp Drill Maintenance: adım 8, 2 resimden 2.
    • Reaching from the sides, use the spudger to insert the armature even farther.
    • Side view. This is far enough.
  9. DeWALT DW106 Amp Drill Maintenance: adım 9, 1 resimden 1.
    • Lay the field/armature assembly down.
    • Place the ball bearing ring on the opposite end of the armature.
  10. DeWALT DW106 Amp Drill Maintenance: adım 10, 1 resimden 1.
    • Place the motor back into the bottom half of the clamshell case.
    • Make sure the three ball bearings are aligned with their receptors. Slightly adjusting the armature inside the field may be necessary.
    Alguien sabe la medida del balero pequeño? Porfa que el de mi taladro se perdió!!
    Cano Rios - Yanıt
  11. DeWALT DW106 Amp Drill Maintenance: adım 11, 1 resimden 1.
    • Replace the spindle and gear assembly.
    • Lift and adjust until the two helical gears are meshed properly.
  12. DeWALT DW106 Amp Drill Maintenance: adım 12, 1 resimden 1.
    • Place the switch into the slot.
    • Tuck the wiring both inside the edge of the case and out of the way of the support pegs.
  13. DeWALT DW106 Amp Drill Maintenance: adım 13, 1 resimden 1.
    • Thread the power cord through the support pegs.
    • Insert the top end of the cord protector into the slot.
  14. DeWALT DW106 Amp Drill Maintenance: adım 14, 1 resimden 1.
    • Replace the level.
  15. DeWALT DW106 Amp Drill Maintenance: adım 15, 1 resimden 1.
    • Using the notch, align the two halves of the clamshell case and close it.
    • Pay special attention to ensure the wiring all stays clear of the support pegs and the ball bearing wheels and level all stay in their slots.
  16. DeWALT DW106 Amp Drill Maintenance: adım 16, 1 resimden 1.
    • Rescrew all seven screws using the T20 driver.
    • To ensure a tight fit, use the T-handle configuration on the screwdriver.
  17. DeWALT DW106 Amp Drill Maintenance: adım 17, 1 resimden 1.
    • Finished.
Sonuç
Plug it in and see if it works more reliably.
5 farklı kişi bu kılavuzu tamamladı.
Joanna
266 İtibar
1 Kılavuz yazıldı
Bir Yorum
Will try tomorrow, thanks in advance!
Martin Wanyama - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 20
Her zaman: 3,635
