Ana içeriğe geç
DeWalt DC970 Motor Replacement
Neye ihtiyacın var
  1. DeWalt DC970 Motor Replacement, Battery: adım 1, 1 resimden 1.
    • Compress the buttons on either side of the battery and lift the drill away from battery.
    FixBot'a Sor
    Yorum Ekle
  2. DeWalt DC970 Motor Replacement: adım 2, 1 resimden 1.
    • Remove battery from drill.
    FixBot'a Sor
    Yorum Ekle
  3. DeWalt DC970 Motor Replacement, Drill Assembly: adım 3, 2 resimden 1. DeWalt DC970 Motor Replacement, Drill Assembly: adım 3, 2 resimden 2.
    • Remove the eight 16 mm, Torx Security #15 screws.
    FixBot'a Sor
    Yorum Ekle
  4. DeWalt DC970 Motor Replacement: adım 4, 1 resimden 1.
    • Lay the drill on its side and gently lift the top half off it.
    FixBot'a Sor
    Yorum Ekle
  5. DeWalt DC970 Motor Replacement, Motor: adım 5, 1 resimden 1.
    • Lift drill mechanism out of the shell.
    • Desolder the red and black wires from the motor.
    • Learn more about soldering here.
    FixBot'a Sor
    Yorum Ekle
  6. DeWalt DC970 Motor Replacement: adım 6, 1 resimden 1.
    • Slightly twist and pull motor away from the clutch.
    FixBot'a Sor
    Yorum Ekle
  7. DeWalt DC970 Motor Replacement: adım 7, 1 resimden 1.
    • When installing the replacement motor into the clutch make sure you correctly align the gears in order to assure that the motor is properly fitted to the clutch.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jonathan Hamel
729 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-2, Catania Spring 2016 UMass Dartmouth, Team 4-2, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S4G2
3 Üyeler
13 adet Kılavuz yazıldı
3Kılavuz Yorumları
Unplug the wires from the trigger switch....don't unsolder.
New motor comes with wires.
allen.anderson1 - Yanıt Paylaş
Thanks for the heads up on the wires
Daniel Randall - Yanıt Paylaş
Is there a fix to replace brushes?
pmac086 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 78
Her zaman: 7,979
