Ana içeriğe geç
DeWalt DWE4011 Power Cable Replacement
Neye ihtiyacın var
  1. DeWalt DWE4011 Power Cable Replacement, Power Cord: adım 1, 1 resimden 1.
    • Turn to the bottom of the device and remove the 5/8" (17mm) T15 Torx screw.
  2. DeWalt DWE4011 Power Cable Replacement: adım 2, 2 resimden 1. DeWalt DWE4011 Power Cable Replacement: adım 2, 2 resimden 2.
    • Remove bottom casing by separating the end handle away from the main casing.
  3. DeWalt DWE4011 Power Cable Replacement: adım 3, 2 resimden 1. DeWalt DWE4011 Power Cable Replacement: adım 3, 2 resimden 2.
    • Remove the 1/2” (13mm) Phillips #2 screw holding the power cable to the device. This will free up the metal clamp holding the cable in place.
  4. DeWalt DWE4011 Power Cable Replacement: adım 4, 1 resimden 1.
    • Flip the grinder over and disconnect the plastic switch mechanism from the cable housing.
  5. DeWalt DWE4011 Power Cable Replacement: adım 5, 2 resimden 1. DeWalt DWE4011 Power Cable Replacement: adım 5, 2 resimden 2.
    • Pull back the yellow tab holding the housing in place using a nylon spudger. Carefully pull the housing out of the casing.
  6. DeWalt DWE4011 Power Cable Replacement: adım 6, 2 resimden 1. DeWalt DWE4011 Power Cable Replacement: adım 6, 2 resimden 2.
    • Locate the terminals with the two white cables attached and disconnect both.
    • These cables are connected to the outer terminals; connect as such during reassembly.
  7. DeWalt DWE4011 Power Cable Replacement: adım 7, 2 resimden 1. DeWalt DWE4011 Power Cable Replacement: adım 7, 2 resimden 2.
    • Remove the entirety of the cable housing from the device casing.
    • The two wires coming from the power cable should still be connected to electrical housing at this point.
  8. DeWalt DWE4011 Power Cable Replacement: adım 8, 1 resimden 1.
    • Loosen the Phillips #2 screws enough to disconnect the two wires from the power cable housing.
    • Removing the screw entirely is fine, but unnecessary since the screws are merely clamping down the wires' ends.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Where can I find a replacement power cord?
Ethan Sligar - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 34
Her zaman: 3,734
