Ana içeriğe geç
Decorative Light Fixture Lightbulb Replacement
Jordan Parry
Jordan Parry ve başka bir katkıda bulunan
En son September 22, 2023 tarihinde güncellendi
1 - 3 dakika
Kolay
Many homes have decorative light fixtures, and for good reason. They look much more interesting than your average lightbulb. However, they also make it harder to change your lightbulbs. That is why knowing how to safely take them apart is a great skill to learn, which is exactly what this guide is here to help you do. Be sure your replacement bulb is compatible with your light fixture.
Before beginning this guide, turn off the power from the circuit breaker, and turn off any light switches that provide power to the item you’re working on.
Neye ihtiyacın var
Aletler
  1. Decorative Light Fixture Lightbulb Replacement, Lightbulb: adım 1, 1 resimden 1.
    • WARNING: Before beginning this guide, turn off the power from the circuit breaker, and turn off any light switches that provide power to the item you’re working on.
    • Position a sturdy ladder beneath the light fixture.
  2. Decorative Light Fixture Lightbulb Replacement: adım 2, 2 resimden 1. Decorative Light Fixture Lightbulb Replacement: adım 2, 2 resimden 2.
    • Hold onto the fixture with one hand, and use the screwdriver to start unscrewing the fixture with your other hand.
    • If possible, have someone else hold the fixture for you.
    • Caution: Be careful not to drop the fixture. Broken glass can be very dangerous.
  3. Decorative Light Fixture Lightbulb Replacement: adım 3, 1 resimden 1.
    • Place the fixture and any loose screws off to the side.
  4. Decorative Light Fixture Lightbulb Replacement: adım 4, 2 resimden 1. Decorative Light Fixture Lightbulb Replacement: adım 4, 2 resimden 2.
    • Unscrew the lightbulb from the fixture.
  5. Decorative Light Fixture Lightbulb Replacement: adım 5, 1 resimden 1.
    • Check to make sure that your replacement lightbulb matches the necessary type for the fixture.
  6. Decorative Light Fixture Lightbulb Replacement: adım 6, 2 resimden 1. Decorative Light Fixture Lightbulb Replacement: adım 6, 2 resimden 2.
    • Re-screw the lightbulb into the fixture.
  7. Decorative Light Fixture Lightbulb Replacement: adım 7, 2 resimden 1. Decorative Light Fixture Lightbulb Replacement: adım 7, 2 resimden 2.
    • Hold onto the fixture, and screw it back in with the screwdriver.
Bitiş Çizgisi
Jordan Parry
145 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 440
