Ana içeriğe geç
Dell AC511 Speaker Replacement
Neye ihtiyacın var
  1. Dell AC511 Speaker Replacement, Front Panel: adım 1, 3 resimden 1. Dell AC511 Speaker Replacement, Front Panel: adım 1, 3 resimden 2. Dell AC511 Speaker Replacement, Front Panel: adım 1, 3 resimden 3.
    • Use a Jimmy to peel off the screen stuck to the front of the speaker.
    • Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
    • Be careful to avoid damage to the rest of the speaker and especially to yourself.
    • Don't worry if it tears; use the Jimmy again to peel off the rest.
  2. Dell AC511 Speaker Replacement: adım 2, 2 resimden 1. Dell AC511 Speaker Replacement: adım 2, 2 resimden 2.
    • Remove ten 6 mm screws using a Phillips #1 screwdriver.
  3. Dell AC511 Speaker Replacement: adım 3, 2 resimden 1. Dell AC511 Speaker Replacement: adım 3, 2 resimden 2.
    • Lift the front panel off of the rest of the device.
    • The speakers will still be attached to the front panel. Being too rough could damage them.
    • Remove the 4 mm screws from the speakers using a JIS #1 screwdriver.
    • Remove the front panel from the device.
  4. Dell AC511 Speaker Replacement, Speaker: adım 4, 2 resimden 1. Dell AC511 Speaker Replacement, Speaker: adım 4, 2 resimden 2.
    • Follow the three wires connected to the speaker to find where they connect to the circuit board.
    • Use tweezers to gently rock the end of the wires back and forth until they disconnect from the board.
Sonuç
William Cook
617 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-6, Shaddix Spring 2024 UMass Dartmouth, Team 4-6, Shaddix Spring 2024 üyesi
UMASSD-SHADDIX-S24S4G6
4 Üyeler
1Rehber Yorum
where can I get the compatible speaker head?
Chanthachon Senesouphap - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 12
Son 30 gün: 56
Her zaman: 272
