Ana içeriğe geç
Dell AC511 Speaker Replacement
William Cook
William Cook ve başka bir katkıda bulunan
En son June 25, 2024 tarihinde güncellendi
2 - 3 dakika
Orta
Daha iyi giriş
If you suspect one or more of the speakers in your Dell AC511 soundbar has stopped working, you may need to replace them.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Dell AC511 Speaker Replacement, Front Panel: adım 1, 3 resimden 1. Dell AC511 Speaker Replacement, Front Panel: adım 1, 3 resimden 2. Dell AC511 Speaker Replacement, Front Panel: adım 1, 3 resimden 3.
    • Use a Jimmy to peel off the screen stuck to the front of the speaker.
    • Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
    • Be careful to avoid damage to the rest of the speaker and especially to yourself.
    • Don't worry if it tears; use the Jimmy again to peel off the rest.
  2. Dell AC511 Speaker Replacement: adım 2, 2 resimden 1. Dell AC511 Speaker Replacement: adım 2, 2 resimden 2.
    • Remove ten 6 mm screws using a Phillips #1 screwdriver.
  3. Dell AC511 Speaker Replacement: adım 3, 2 resimden 1. Dell AC511 Speaker Replacement: adım 3, 2 resimden 2.
    • Lift the front panel off of the rest of the device.
    • The speakers will still be attached to the front panel. Being too rough could damage them.
    • Remove the 4 mm screws from the speakers using a JIS #1 screwdriver.
    • Remove the front panel from the device.
  4. Dell AC511 Speaker Replacement, Speaker: adım 4, 2 resimden 1. Dell AC511 Speaker Replacement, Speaker: adım 4, 2 resimden 2.
    • Follow the three wires connected to the speaker to find where they connect to the circuit board.
    • Use tweezers to gently rock the end of the wires back and forth until they disconnect from the board.
Sonuç
William Cook
617 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-6, Shaddix Spring 2024 UMass Dartmouth, Team 4-6, Shaddix Spring 2024 üyesi
UMASSD-SHADDIX-S24S4G6
4 Üyeler
Bir Yorum
where can I get the compatible speaker head?
Chanthachon Senesouphap - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 20
Son 30 gün: 44
Her zaman: 247
