Ana içeriğe geç
Dell Inpiron 3542 Motherboard Replacement
Neye ihtiyacın var
  1. Dell Inpiron 3542 Motherboard  Replacement, Motherboard: adım 1, 2 resimden 1. Dell Inpiron 3542 Motherboard  Replacement, Motherboard: adım 1, 2 resimden 2.
    • Slide the latches on both sides of the laptop outward to unlock the battery.
    • Remove the battery from the computer.
    • Replacing a motherboard can lead to data loss. Make sure to backup any important data on the laptop before replacing the motherboard.
    Hi. Looking for a compatible motherboard for dell inspiron 15-3542.
    eric.mwakibengele - Yanıt
  2. Dell Inpiron 3542 Motherboard  Replacement: adım 2, 2 resimden 1. Dell Inpiron 3542 Motherboard  Replacement: adım 2, 2 resimden 2.
    • Remove the screw. (1 x M2 x 3mm)
    • Slide down the access door and remove it.
  3. Dell Inpiron 3542 Motherboard  Replacement: adım 3, 3 resimden 1. Dell Inpiron 3542 Motherboard  Replacement: adım 3, 3 resimden 2. Dell Inpiron 3542 Motherboard  Replacement: adım 3, 3 resimden 3.
    • Move the hard drive to the open area and remove it.
  4. Dell Inpiron 3542 Motherboard  Replacement: adım 4, 3 resimden 1. Dell Inpiron 3542 Motherboard  Replacement: adım 4, 3 resimden 2. Dell Inpiron 3542 Motherboard  Replacement: adım 4, 3 resimden 3.
    • Unplug the black and white antenna cables from the wireless card.
    • Remove the wireless card from the laptop.
  5. Dell Inpiron 3542 Motherboard  Replacement: adım 5, 2 resimden 1. Dell Inpiron 3542 Motherboard  Replacement: adım 5, 2 resimden 2.
    • Remove all screws from the bottom of the laptop. (10 x M2.5 x 5mm)
    • Turn over the laptop and open it.
  6. Dell Inpiron 3542 Motherboard  Replacement: adım 6, 2 resimden 1. Dell Inpiron 3542 Motherboard  Replacement: adım 6, 2 resimden 2.
    • Use the plastic prying device to release the keyboard. Avoid from using excessive force to prevent damages.
    • Lift the keyboard.
    • Unplug the cable connecting the keyboard to the laptop.
    • Remove the keyboard.
  7. Dell Inpiron 3542 Motherboard  Replacement: adım 7, 3 resimden 1. Dell Inpiron 3542 Motherboard  Replacement: adım 7, 3 resimden 2. Dell Inpiron 3542 Motherboard  Replacement: adım 7, 3 resimden 3.
    • Unplug the touch pad cables located on the palm rest.
    • Remove the screws. (3 x M2.5 x 5mm)
  8. Dell Inpiron 3542 Motherboard  Replacement: adım 8, 2 resimden 1. Dell Inpiron 3542 Motherboard  Replacement: adım 8, 2 resimden 2.
    • Carefully unsnap the palm rest from the rest of the laptop.
    • Remove the palm rest.
  9. Dell Inpiron 3542 Motherboard  Replacement: adım 9, 1 resimden 1.
    • Unplug the cable that connects to the motherboard.
    • Remove the DC jack from the laptop.
  10. Dell Inpiron 3542 Motherboard  Replacement: adım 10, 1 resimden 1.
    • Loosen the cables on the antenna.
  11. Dell Inpiron 3542 Motherboard  Replacement: adım 11, 2 resimden 1. Dell Inpiron 3542 Motherboard  Replacement: adım 11, 2 resimden 2.
    • Remove the screws. (1 x M2 x 3mm)
    • Unplug the circuit board from the rest of the computer.
  12. Dell Inpiron 3542 Motherboard  Replacement: adım 12, 1 resimden 1.
    • Loosen the tape on the left side of the laptop.
    • Unplug the display cable.
  13. Dell Inpiron 3542 Motherboard  Replacement: adım 13, 2 resimden 1. Dell Inpiron 3542 Motherboard  Replacement: adım 13, 2 resimden 2.
    • Unplug the cable on the bottom part of the mother board.
    • Remove the cable on the right side of the motherboard. (3x M2.5 x 5mm)
    • Remove the motherboard from the laptop.
Sonuç
To reassemble your device, follow these instructions in reverse order. Congratulations on replacing the Motherboard on your Dell Inpiron 3542.
5 farklı kişi bu kılavuzu tamamladı.
Rachel lindsey
733 İtibar
5 adet Kılavuz yazıldı
Ekip
Texas Tech, Team S46-G1, Bennett Spring 2017 Texas Tech, Team S46-G1, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S46G1
3 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Anyone know where I can purchase a board for a Dell Inspiron 3542 in the UK?
Darrell Haslam - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 39
Her zaman: 3,756
