Ana içeriğe geç
Dell Inspiron 11 i3147 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 11 i3147 Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Close the computer and turn it over, with the bottom of the computer facing up.
  2. Dell Inspiron 11 i3147 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Remove the nine 7.6mm PH0 screws on the cover.
  3. Dell Inspiron 11 i3147 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Use a plastic opening tool to remove the cover from the computer.
  4. Dell Inspiron 11 i3147 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Remove the three 4.7mm PH0 screws that secure the battery to the computer.
  5. Dell Inspiron 11 i3147 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Remove the hard drive cable from the battery.
  6. Dell Inspiron 11 i3147 Hard Drive Replacement: adım 6, 1 resimden 1.
    • Lift the battery from the computer.
  7. Dell Inspiron 11 i3147 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Peel off the adhesive strap from the hard drive.
  8. Dell Inspiron 11 i3147 Hard Drive Replacement: adım 8, 1 resimden 1.
    • Use a PH0 screwdriver to remove the 2 3.9 mm PH0 screws on the hard drive.
  9. Dell Inspiron 11 i3147 Hard Drive Replacement: adım 9, 1 resimden 1.
    • Lift the hard drive to free it from the laptop.
  10. Dell Inspiron 11 i3147 Hard Drive Replacement: adım 10, 1 resimden 1.
    • Remove interposer from the hard drive.
  11. Dell Inspiron 11 i3147 Hard Drive Replacement: adım 11, 1 resimden 1.
    • Use pull tab to remove hard drive cable from motherboard.
Sonuç
Muhammad Erchid
1.069 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G6, Leahy Fall 2018 USF Tampa, Team S1-G6, Leahy Fall 2018 üyesi
USFT-LEAHY-F18S1G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 271
